Inaccurate results for int8 in cublasGemmEx
When using cublasGemmEx with CUDA_R_8I for A and B, and CUDA_R_32I for C, I’m getting results that slightly differ from the actual results. This all sounds pretty exactly like the float bug that was supposedly fixed in 12.3.1: 1. CUDA 12.4 Release Notes — Release Notes 12.4 documentation
“cublasLtMatmul with A and B types equal CUDA_R_8I, scale and C type equal CUDA_R_32I and compute type equals CUBLAS_COMPUTE_32I{,_PEDANTIC} could erroneously perform casting of the result to float data type and then back to integer which result in accuracy loss (for output greater than 2^24). The issue exists since cuBLAS 11.0.”
However, also when updating to the latest CUDA Version 12.4, I still get the inaccurate results. Interestingly, the bug only seems to occur on Hopper (H100 in my test), neither on A100 nor RTX4090. Here is a little demo. Would be interesting to see if this bug is also reproducible for others or my CUDA version update went wrong.
#include <cublas_v2.h>
#include <cuda_runtime.h>
#include <iostream>
#include <vector>
#include <cstdlib>
#include <ctime>
// Basic CPU impl
void simpleCpuGemm(int m, int n, int k, const int8_t *A, const int8_t *B, int32_t *C)
    for (int row = 0; row < m; ++row)
        for (int col = 0; col < n; ++col)
            int32_t sum = 0;
            for (int i = 0; i < k; ++i)
                sum += A[i + row * k] * B[i + col * k];
            C[row + col * m] = sum;
int main()
    cublasHandle_t handle;
    cublasCreate(&handle);
    int m = 100, n = 32, k = 12800;
    std::srand(std::time(0));
    std::vector<int8_t> h_A(m * k);
    std::vector<int8_t> h_B(k * n);
    std::vector<int32_t> h_C(m * n);
    std::vector<int32_t> h_C_cpu(m * n);
    for (int i = 0; i < m * k; ++i)
        h_A[i] = static_cast<int8_t>(std::rand() % 127);
    for (int i = 0; i < k * n; ++i)
        h_B[i] = static_cast<int8_t>(std::rand() % 127);
    int8_t *A, *B;
    int32_t *C;
    cudaMalloc(&A, m * k * sizeof(int8_t));
    cudaMalloc(&B, k * n * sizeof(int8_t));
    cudaMalloc(&C, m * n * sizeof(int32_t));
    cudaMemcpy(A, h_A.data(), m * k * sizeof(int8_t), cudaMemcpyHostToDevice);
    cudaMemcpy(B, h_B.data(), k * n * sizeof(int8_t), cudaMemcpyHostToDevice);
    const int32_t alpha = 1;
    const int32_t beta = 0;
    // Matmul using cublasGemmEx
    cublasGemmEx(handle, CUBLAS_OP_T, CUBLAS_OP_N,
                 m, n, k,
                 &alpha,
                 A, CUDA_R_8I, k,
                 B, CUDA_R_8I, k,
                 &beta,
                 C, CUDA_R_32I, m,
                 CUBLAS_COMPUTE_32I_PEDANTIC, CUBLAS_GEMM_DEFAULT);
    cudaMemcpy(h_C.data(), C, m * n * sizeof(int32_t), cudaMemcpyDeviceToHost);
    // CPU sanity check
    simpleCpuGemm(m, n, k, h_A.data(), h_B.data(), h_C_cpu.data());
    // Compare the results
    int diffs = 0;
    for (int i = 0; i < m * n; ++i)
        if (h_C_cpu[i] != h_C[i])
            std::cout << h_C_cpu[i] << " " << h_C[i] << " " << i << "\n";
            diffs++;
    std::cout << "The results " << (diffs == 0 ? "MATCH" : "DO NOT MATCH") << ": " << diffs << " out of " << n * m << " values differ\n";
    cudaFree(A);
    cudaFree(B);
    cudaFree(C);
    cublasDestroy(handle);
    return 0;
Hi @philzip1 , thanks for the report! I was able to reproduce the issue with 12.4, so it sounds like the release notes were incorrect. The issue is actually fixed in an upcoming release. In the meantime, the release notes have been corrected.
thanks for the reply @kwierschem. But it was not included in the recently published minor release?
Yes, that’s correct. The fix is not included in either 12.4 or 12.4 Update 1, but should be part of a later release.
