Including <cub/cub.cuh>
and <immintrin.h>
breaks compilation with GCC 12, if the SSE2 instruction set is enabled.
Here is a simple reproducer, test.cu
#include <cub/cub.cuh>
#include <immintrin.h>
__global__
void unused() {}
Compiling with
/usr/local/cuda-12.1/bin/nvcc -ccbin g++-12 --compiler-options "-msse2" test.cu -c -o test.o
fails with
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512fp16intrin.h(38): error: vector_size attribute requires an arithmetic or enum type
__v8hf __attribute__ ((__vector_size__ (16)));
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512fp16intrin.h(39): error: vector_size attribute requires an arithmetic or enum type
__v16hf __attribute__ ((__vector_size__ (32)));
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512fp16intrin.h(40): error: vector_size attribute requires an arithmetic or enum type
__v32hf __attribute__ ((__vector_size__ (64)));
(... 95 more errors ...)
Killed
I’ve traced this down to:
- the header
.../include/cub/cub.cuh
indirectly includes the header.../include/cuda/std/detail/__config
defines_Float16
as#define _Float16 __half
- this conflicts with GCC’s use of
_Float16
on x86 systems with SSE2, and on ARM
_Float16
is used in GCC’s headers <avx512fp16vlintrin.h>
and <avx512fp16intrin.h>
, that are included by <immintrin.h>
A simple workaround seems to be to #undef _Float16
after including <cub/cub.cuh>
, but I have no idea if this may lead to other conflicts in a more realistic program:
#undef _Float16
__global__
void unused() {}
compiles fine.
