hello,
I’ve encountered an issue with the NVIDIA API for generating conversations. It seems to return an incomplete message when ‘max_tokens’ is not specified in the request.
A screenshot demonstrating the problem, the first response is incomplete:
The following code reproduces the issue. Note that the ‘max_tokens’ parameter has been intentionally left out:
curl https://integrate.api.nvidia.com/v1/chat/completions \
-H "Content-Type: application/json" \
-H "Authorization: Bearer $API_KEY_REQUIRED_IF_EXECUTING_OUTSIDE_NGC" \
-d '{
"model": "meta/llama3-70b-instruct",
"messages": [{"role":"user","content":"longtime no see"}],
"temperature": 0.5,
"top_p": 1,
"stream": false
Without specifying ‘max_tokens’, I would expect the API to provide a default length for the message. However, the response seems to be unexpectedly truncated or incomplete.
Thank you for your reading.
