I am doing some comparisons between two values within a kernel and writing a 1 to a matrix if they are equal and 0 if not. However, when I read a location from the matrix where it is supposed to produce 1, i find it a 0. If i read the value from the matrix immediatly after its written inside the loop, i get the correct value. But if i read it after the loop is done, the result is incorrect.
__global__ void
propagateGPU1(clause** clauses, vecp* dclauses, int* assign, short* dmatrix, size_t pitch, int* testv, short* stestv)
int i;
int j;
const unsigned int tid = threadIdx.x;
for(i = 0; i < dclauses->size; i++){
short* row = (short*)((char*)dmatrix + i * pitch);
for(j = 0; j < dclause_size(&clauses[0][i*64]); j++){
if(assign[tid] == (clauses[0][i*64].lits[j])){
row[tid] = 1;
//if(tid == 15 && i == 0 && j ==0)*stestv = dmatrix[15]; <--- when this is enabled, it produces a 1
else{
row[tid] = 0;
//if(tid == 15 && i == 0 && j ==0)**stestv = dmatrix[15];
if(tid == 15)**stestv = dmatrix[15]; <---- this gives a 0
I know for a fact that the result should be 1 based on the inputs which I have checked within the kernel are correct. both assign[15] and clauses[0][0].lits[0] are equal so the result should be 1. I am not doing anything between the loop and reading the value from the matrix but for some reason the result got changed.
pitch size is = 128 and the problem i am having is at i = 0 and j = 0
Could anyone please help me understand this problem? Your help is very much appreciated…
