The following code compiles correctly with gfortran and ifx, but fails with nvfortran 25.11
code.f90
MODULE m
TYPE :: t
PRIVATE
CONTAINS
PROCEDURE :: f1 => t_f1
PROCEDURE :: f2 => t_f2
GENERIC :: f => f1, f2
END TYPE
CONTAINS
INTEGER FUNCTION f(i)
INTEGER :: i
f = i
END FUNCTION
INTEGER FUNCTION t_f1(this, i, j)
CLASS(t) :: this
INTEGER :: i, j
t_f1 = i + j
END FUNCTION
INTEGER FUNCTION t_f2(this, i, j, k)
CLASS(t) :: this
INTEGER :: i, j, k
t_f2 = i + j + k
END FUNCTION
SUBROUTINE s
PRINT*,f(1)
END SUBROUTINE
END MODULE m
> nvfortran -c code.f90
NVFORTRAN-S-0155-Could not resolve generic procedure f (code.f90: 28)
0 inform, 0 warnings, 1 severes, 0 fatal for s
f is not a generic prodedure in that module. Only the type-bound procudure t%f is generic. I can work around the bug by renaming f.
