I am have made modifications to the jetbot.py file located in /isaac_sim-2021.2.1/exts/omni.isaac.jetbot/omni/isaac/jetbot/
to replace the jetbot.usd model with the carter_v1.usd model. I have also changed the camera reference path to match that of the carter v1. When I load up the RL example, as shown in this tutorial: 19. Reinforcement Learning using Stable Baselines — Omniverse Robotics documentation , I can see that the Carter Robot loaded in properly but the program exits out after loading the environment and I get this error in the jetbot.py code:
File "standalone_examples/api/omni.isaac.jetbot/stable_baselines_example/eval.py", line 19, in <module>
obs = my_env.reset()
File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/standalone_examples/api/omni.isaac.jetbot/stable_baselines_example/env.py", line 91, in reset
self._my_world.reset()
File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/world/world.py", line 174, in reset
self.scene.post_reset()
File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/scenes/scene.py", line 186, in post_reset
prim_registery[prim_name].post_reset()
File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.jetbot/omni/isaac/jetbot/jetbot.py", line 153, in post_reset
self._articulation_controller.set_gains(kds=[1e2, 1e2])
File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/controllers/articulation_controller.py", line 159, in set_gains
self._dof_controllers[i].set_gains(dof_props, kp=kps[i], kd=kds[i])
IndexError: list index out of range
I have found the error regarding the set_gains for the jetbot.py code, but I’m not sure how to modify it to fit the Carter V1 bot. I have included my modifications below including the original code values in the comments. A video of my error is linked as well: Isaac Sim Crash - YouTube Thanks for your time.
from typing import Optional, Tuple
import numpy as np
from omni.isaac.core.robots.robot import Robot
from omni.isaac.core.utils.nucleus import find_nucleus_server
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.core.utils.prims import get_prim_at_path, define_prim
import carb
class Jetbot(Robot):
"""[summary]
Args:
stage (Usd.Stage): [description]
prim_path (str): [description]
name (str): [description]
usd_path (str, optional): [description]
position (Optional[np.ndarray], optional): [description]. Defaults to None.
orientation (Optional[np.ndarray], optional): [description]. Defaults to None.
def __init__(
self,
prim_path: str,
name: str = "jetbot",
usd_path: Optional[str] = None,
position: Optional[np.ndarray] = None,
orientation: Optional[np.ndarray] = None,
) -> None:
prim = get_prim_at_path(prim_path)
if not prim.IsValid():
prim = define_prim(prim_path, "Xform")
if usd_path:
prim.GetReferences().AddReference(usd_path)
else:
result, nucleus_server = find_nucleus_server()
if result is False:
carb.log_error("Could not find nucleus server with /Isaac folder")
return
# Edited this asset path to replace jetbot with carter v1
# original path: /Isaac/Robots/Jetbot/jetbot.usd
asset_path = nucleus_server + "/Isaac/Robots/Carter/carter_v1.usd"
prim.GetReferences().AddReference(asset_path)
super().__init__(
prim_path=prim_path, name=name, position=position, orientation=orientation, articulation_controller=None
# Original Links for _wheel_dof_names
# ["left_wheel_joint", "right_wheel_joint"]
self._wheel_dof_names = ["left_wheel", "right_wheel"]
self._wheel_dof_indices = None
# TODO: check the default state and how to reset
return
@property
def wheel_dof_indices(self) -> Tuple[int, int]:
"""[summary]
Returns:
int: [description]
return self._wheel_dof_indices
def get_wheel_positions(self) -> Tuple[float, float]:
"""[summary]
Returns:
Tuple[float, float]: [description]
joint_positions = self.get_joint_positions()
return joint_positions[self._wheel_dof_indices[0]], joint_positions[self._wheel_dof_indices[1]]
def set_wheel_positions(self, positions: Tuple[float, float]) -> None:
"""[summary]
Args:
positions (Tuple[float, float]): [description]
joint_positions = [None, None]
joint_positions[self._wheel_dof_indices[0]] = positions[0]
joint_positions[self._wheel_dof_indices[1]] = positions[1]
self.set_joint_positions(positions=np.array(joint_positions))
return
def get_wheel_velocities(self) -> Tuple[float, float]:
"""[summary]
Returns:
Tuple[np.ndarray, np.ndarray]: [description]
joint_velocities = self.get_joint_velocities()
return joint_velocities[self._wheel_dof_indices[0]], joint_velocities[self._wheel_dof_indices[1]]
def set_wheel_velocities(self, velocities: Tuple[float, float]) -> None:
"""[summary]
Args:
velocities (Tuple[float, float]): [description]
joint_velocities = [None, None]
joint_velocities[self._wheel_dof_indices[0]] = velocities[0]
joint_velocities[self._wheel_dof_indices[1]] = velocities[1]
self.set_joint_velocities(velocities=np.array(joint_velocities))
return
def apply_wheel_actions(self, actions: ArticulationAction) -> None:
"""[summary]
Args:
actions (ArticulationAction): [description]
actions_length = actions.get_length()
if actions_length is not None and actions_length != 2:
raise Exception("ArticulationAction passed should be equal to 2")
joint_actions = ArticulationAction()
if actions.joint_positions is not None:
joint_actions.joint_positions = np.zeros(self.num_dof)
joint_actions.joint_positions[self._wheel_dof_indices[0]] = actions.joint_positions[0]
joint_actions.joint_positions[self._wheel_dof_indices[1]] = actions.joint_positions[1]
if actions.joint_velocities is not None:
joint_actions.joint_velocities = np.zeros(self.num_dof)
joint_actions.joint_velocities[self._wheel_dof_indices[0]] = actions.joint_velocities[0]
joint_actions.joint_velocities[self._wheel_dof_indices[1]] = actions.joint_velocities[1]
if actions.joint_efforts is not None:
joint_actions.joint_efforts = np.zeros(self.num_dof)
joint_actions.joint_efforts[self._wheel_dof_indices[0]] = actions.joint_efforts[0]
joint_actions.joint_efforts[self._wheel_dof_indices[1]] = actions.joint_efforts[1]
self.apply_action(control_actions=joint_actions)
return
def initialize(self) -> None:
"""[summary]
super().initialize()
self._wheel_dof_indices = (
self.get_dof_index(self._wheel_dof_names[0]),
self.get_dof_index(self._wheel_dof_names[1]),
return
def post_reset(self) -> None:
"""[summary]
super().post_reset()
self._articulation_controller.switch_control_mode(mode="velocity")
return
