I am writing to seek some workarounds for the error “Indirect function/procedure calls are not supported”. A simple code is pasted below.
#include <iostream>
class EquationOfStateFR
public:
EquationOfStateFR(){}
virtual ~EquationOfStateFR(){}
virtual void createDeviceData(){}
public:
inline virtual int computePressure(){return 5;}
class EOS_IdealGas : public EquationOfStateFR
public:
inline EOS_IdealGas(){}
inline ~EOS_IdealGas(){}
#pragma acc enter data copyin(this)
public:
#pragma acc routine seq
inline int computePressure(){return 10;}
class solveSystem
public:
solveSystem(){_equationOfState = new EOS_IdealGas;}
~solveSystem(){}
_equationOfState->createDeviceData();
#pragma acc enter data attach(_equationOfState)
public:
void calculation()
out=_equationOfState->computePressure();
void print_val()
#pragma acc update self(out)
std::cout << "out=" << out << std::endl;
private:
EOS_IdealGas* _equationOfState;
int out;
int main()
solveSystem obj;
obj.createDeviceData();
#pragma acc serial
obj.calculation();
obj.print_val();
During compilation (with ‘pgc++ -acc -ta=nvidia -Minfo=accel indirect5.C’), the following errors arise:
main:
59, Accelerator serial kernel generated
Generating Tesla code
Generating implicit copy(obj)
EOS_IdealGas::createDeviceData():
21, Generating enter data copyin(this[:1])
EOS_IdealGas::computePressure():
24, Generating acc routine seq
solveSystem::createDeviceData():
35, Generating enter data copyin(this[:1])
37, Generating enter data attach(_equationOfState)
PGCC-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Indirect function/procedure calls are not supported (indirect5.C: 42)
solveSystem::calculation():
41, Generating acc routine seq
42, Accelerator restriction: Indirect function/procedure calls are not supported
PGCC-F-0704-Compilation aborted due to previous errors. (indirect5.C)
PGCC/x86 Linux 18.10-1: compilation aborted
I am aware that currently OpenACC does not support virtual functions in the device code, and it is perhaps why I received this error (could you confirm? It is a bit surprising that even using a derived class pointer is not allowed once virtual functions are present). My intention is therefore to seek your suggestions and recommendations on workarounds. Since we do not want to break the polymorphism by removing the ‘virtual’ qualifier, is it true that our last resort is to create a new function like ‘computePressure_acc’ only in the derived (EOS_IdealGas) class?
Thanks,
Shine
