Hello! I’ve gstreamer application written in Python that runs inference in the image frames using a tflite model by calling invoke on the Interpreter class from tflite (my code is here btw: GitHub - espiriki/JetsonGstreamer: My scripts for jetson gstreamer)
I’m wondering: is that inference running on CPU-only? Does it take advantage of the GPU at all? Is there any way to check that?
It takes around 150ms for a mobilenet_v1_1.0_224, this seems a bit slow to me
This depends on if TFLite supports GPU mode.
A simple way to check is to monitor the GPU utilization with tegrastats.
$ sudo tegrastats
Thank you! I’m seeing something like that:
RAM 968/1980MB (lfb 16x4MB) SWAP 0/5086MB (cached 0MB) CPU [67%@1479,78%@1479,84%@1479,81%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@33C CPU@37C PMIC@100C GPU@31.5C AO@39.5C thermal@35.5C
I guess it is running full CPU
I’ll look into if tflite supports Jetson hardware
system
Closed
6
