My TX2 is flashed with the latest jetpack(4.2.2)
I converted a tensorflow keras model to tensorrt graph using this parameters
trt_graph = trt.create_inference_graph(
input_graph_def=frozen_graph,
outputs=output_names,
max_batch_size=2,
max_workspace_size_bytes=2 << 10,
precision_mode='FP32'
then load the graph and run inference in the for loop.
graph = tf.Graph()
with graph.as_default():
with tf.Session(config=tf.ConfigProto(gpu_options=tf.GPUOptions(per_process_gpu_memory_fraction=0.50))) as sess:
# obtain the corresponding input-output tensor
tf.import_graph_def(relevance_graph, name='')
input = sess.graph.get_tensor_by_name(input_name)
output = sess.graph.get_tensor_by_name(output_name)
out_pred = sess.run(output, { input_name: tensor })
The problem is when i run the code my os is hangs or worker (redis queue is used) dies.
What am i missing?
