Hi All,
I am thinking for a solution to make inference only on the area of interest not on a full screen(need to perform inference only on the set area coordinates).
How can this be achieved in Holoscan ?
Hi All,
Hi there, sorry for the late reply, at this moment, you could add your custom operator to do the cropping of the frame (simplest would be in Numpy, Cupy or other libraries), and pass the cropped frame downstream to the inference operator.
Thank you, Can this be applied for livestream videos as well? Please suggest other libraries other than Cupy or Numpy
Yes this can be applied for live stream frames too. You can choose any GPU accelerated libraries you are familiar with, in the C++ API or Python API, it doesn’t need to be Cupy or Numpy. Please see Creating Operators - NVIDIA Docs
This
holoscan::Tensorclass is a wrapper around theDLManagedTensorCtxstruct holding a DLManagedTensor object. As such, it provides a primary interface to access Tensor data and is interoperable with other frameworks that support the DLPack interface.
This
holoscan.core.Tensorclass supports both DLPack and NumPy’s array interface (__array_interface__and__cuda_array_interface__) so that it can be used with other Python libraries such as CuPy, PyTorch, JAX, TensorFlow, and Numba. See the interoperability section for more details.
