No problem. And actually I cannot reproduce this kind of issue all the time.
But some end users meet this problem.
So, could you share more info about the reproduce step and training environment?
For example,
The cuda/trt version in your local PC
The jupyter notebook . You can upload the .ipynb file here.
jupyter notebook
attached. it is yolo_v4.ipynb in cv_samples_vv1.2.0, which was downloaded from ngc.
I did not follow the notebook literally. My network is not stable. So instead of retrying download the 12G image file for days, I downloaded and extracted the images from a mirror inside my country, and from outside of the notebook.
I also ssh to the machine that running the notebook. X11 problems bothered me. So I change !tao yolo_v4 train to !echo tao … and execute the command in terminal.
cuda
both cuda-10-2 and cuda-11-1 installed, /usr/local/cuda links to 11-1 ultimately.
trt 7.2.2-1+cuda11.1
As I tried to use darknet_xxx.weights with deepsteam 4.5.1, I have replace libnvinfer_plugin.so.7.2.2 with the version built with TensorrtOSS 7.2.2.
Additional info:
os: ubuntu 18.04, nvidia related package installed from nvidia cuda/machine-learning repo.
Your cal.bin does the trick. Now I got mAP 0.90074. Thank you!
My purpose is train the model using custom dataset. Can I use your cal.bin when the .tlt model is ready?
Comparing to local generated cal.bin, this time there are lots of warning like:
[WARNING] Missing dynamic range for tensor (Unnamed Layer* 306) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
[WARNING] Missing dynamic range for tensor activation_2/Relu:0, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
