Infiniband performance tuning
I am trying to tune the setup I have to improve the performance of the infiniband network to the maximum possible. The current setup is as follows.
1 Dell T3600 quad core, 3.6GHz node
1 Supermicro dual quad core, 2.4GHz node
40Gbps dual port QDR cards in both the machines. Cards report up and running at 4X QDR on both the machines.
1 Mellanox IS5022 switch
I have used the following document to mount a ramdisk from the supermicro box on the dell box and then tune the various parameters as suggested by mellanox for maximum performance.
HowTo Configure NFS over RDMA (RoCE) https://community.mellanox.com/s/article/howto-configure-nfs-over-rdma--roce-x
Performance Tuning for Mellanox Adapters https://community.mellanox.com/s/article/performance-tuning-for-mellanox-adapters
The following are the performance numbers that I am getting after all the tuning.
I am using perftest-3.2 to run a ib_write_bw test to test the network.
On the server side,
./ib_write_bw -F -a -i 2 --report_gbits
  • Waiting for client to connect… *
RDMA_Write BW Test
Dual-port : OFF Device : mlx4_0
Number of qps : 1 Transport type : IB
Connection type : RC Using SRQ : OFF
CQ Moderation : 100
Mtu : 2048[B]
Link type : IB
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
local address: LID 0x3e QPN 0x0220 PSN 0x5f2422 RKey 0x011102 VAddr 0x007f4c1dd87000
remote address: LID 0x40 QPN 0x022f PSN 0x1afac0 RKey 0xa80993cc VAddr 0x007f197680b000
#bytes #iterations BW peak[Gb/sec] BW average[Gb/sec] MsgRate[Mpps]
8388608 5000 28.75 28.75 0.000428
On the client side,
./ib_write_bw -F -a --report_gbits 192.168.20.253
RDMA_Write BW Test
TX depth : 128
CQ Moderation : 100
Mtu : 2048[B]
Link type : IB
rdma_cm QPs : OFF
local address: LID 0x40 QPN 0x022f PSN 0x1afac0 RKey 0xa80993cc VAddr 0x007f197680b000
remote address: LID 0x3e QPN 0x0220 PSN 0x5f2422 RKey 0x011102 VAddr 0x007f4c1dd87000
2 5000 0.16 0.13 8.331405
4 5000 0.32 0.31 9.757306
8 5000 0.64 0.62 9.765456
16 5000 1.28 1.26 9.861474
32 5000 2.55 2.48 9.689547
64 5000 5.12 4.95 9.670853
128 5000 10.10 9.55 9.324976
256 5000 20.21 17.22 8.407847
512 5000 26.72 24.94 6.088563
1024 5000 28.61 28.53 3.482441
2048 5000 28.60 28.49 1.738749
4096 5000 28.56 28.56 0.871647
8192 5000 28.75 28.75 0.438630
16384 5000 28.74 28.74 0.219247
32768 5000 28.74 28.74 0.109631
65536 5000 28.74 28.74 0.054817
131072 5000 28.75 28.75 0.027418
262144 5000 28.75 28.75 0.013707
524288 5000 28.75 28.75 0.006855
1048576 5000 28.75 28.75 0.003427
2097152 5000 28.75 28.75 0.001714
4194304 5000 28.75 28.75 0.000857
In order to test it further, I copied a 5GB file from a ramdisk to the mounted ramdisk on supermicro and timed the copy.
time cp /mnt/ramdiskDEV/myrandomfile /mnt/ramdiskNAS
real 0m3.931s
user 0m0.004s
sys 0m2.748s
It looks like the copy is occurring at 10.17Gbps which seems quite low compared to the 40Gbps hardware and also with respect to 28.75 Gbps being reported by perftest. What am I missing here and how can I improve the performance of the infiniband network?
Any help is greatly appreciated!!
Krishna
The RDMA is basic performance test between the memory of one computer into that of another without involving either one’s operating system or CPU
The only thing that can affect the performance is the BIOS settings and the cable type.
I suggest to follow the Performance Tuning for Mellanox Adapters https://community.mellanox.com/s/article/performance-tuning-for-mellanox-adapters and set the BIOS settings as recommended and check the cable type .
You shouldn’t mix I/O system and network performance. Follow Mellanox Tuning Guide in order to achieve good network performance and after that start with I/O
