Inquiring About Compute Impact of Fractional Downscale on Jetson Orin NX
Hi NVIDIA Community,
I’ve been working with fractional downscaling on an Jetson Orin NX and have noticed that it tends to increase the compute load significantly. As a result, I’m sometimes unable to maintain the desired FPS. I’m wondering if anyone here has encountered similar issues and if there’s a reference table or documentation that outlines the compute impact for different fractional downscaling ratios on the Jetson Orin.
Any insights or guidance would be greatly appreciated!
Please share more information about fractional downscale. We don’t know much about the software stacks.
You can run sudo tegrastats to check if it used GPU engine or CPU cores.
Downscale is fractional if its ratio is non-integer. For example, doing downscale to video from 5MP to 2MP:
original: 2560 x1920 and the output is 1920 x1080
Width downscale ratio: 2560/1920 = 1.333
Heigh downscale ratio: 1920/1080 = 1.778
On Jetson devices, there is hardware converter which can do downscaling. It is supported in gstreamer and jetson_miltimedia_api. Which interface is used in your use-case?
We use gstreamer.
Please share the gstreamer pipeline for reference. We can check and suggest next.
After we internally re-checked it, we found neglectable difference when the downscale factor is fractional vs non-fractional (using VIC).
Thanks,
Oz
PS: gstreamer pipeline example:
gst-launch-1.0 -e rtspsrc location=rtsp://$username:$password\!@${ip}:554/${stream_url} ! application/x-rtp, media=video, encoding-name=H265 ! queue ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvidconv ! "video/x-raw(memory:NVMM),width=${width},height=$height" ! nvv4l2h264enc ! h264parse ! mp4mux ! filesink location=${output}
