Hello all,
I’d like to build a custom module on the Nano board itself by following below steps :
sudo ln -s /usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9 /lib/modules/4.9.140-g8368ac5/build
hello.c :
* hello-1.c - The simplest kernel module.
#include <linux/module.h> /* Needed by all modules */
#include <linux/kernel.h> /* Needed for KERN_INFO */
int init_module(void)
printk(KERN_INFO "Hello world 1.\n");
* A non 0 return means init_module failed; module can't be loaded.
return 0;
void cleanup_module(void)
printk(KERN_INFO "Goodbye world 1.\n");
Makefile :
obj-m += hello.o
hello:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
The module gets compiled well :
-rw-rw-r-- 1 toto toto 445 Thg 3 13 14:46 hello.c
-rw-rw-r-- 1 toto toto 196064 Thg 3 13 15:13 hello.ko
-rw-rw-r-- 1 toto toto 336 Thg 3 13 15:13 .hello.ko.cmd
-rw-rw-r-- 1 toto toto 762 Thg 3 13 15:13 hello.mod.c
-rw-rw-r-- 1 toto toto 102032 Thg 3 13 15:13 hello.mod.o
-rw-rw-r-- 1 toto toto 29139 Thg 3 13 15:13 .hello.mod.o.cmd
-rw-rw-r-- 1 toto toto 96848 Thg 3 13 15:13 hello.o
-rw-rw-r-- 1 toto toto 29340 Thg 3 13 15:13 .hello.o.cmd
-rw-rw-r-- 1 toto toto 160 Thg 3 13 15:10 Makefile
-rw-rw-r-- 1 toto toto 64 Thg 3 13 15:13 modules.order
-rw-rw-r-- 1 toto toto 0 Thg 3 13 15:13 Module.symvers
drwxrwxr-x 2 toto toto 4096 Thg 3 13 15:13 .tmp_versions/
But I get following error when trying to insert it :
insmod: ERROR: could not insert module hello.ko: Invalid module format
$ file hello.ko
hello.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=44c6a16f51b7911c767f1ab9e5806a6ee03fd7f0, with debug_info, not stripped
I’d like to know if the above approach is possible since I found other approach to recompile and flash the whole kernel rather than individual module. For example, following thread said that similar approach on TX1 was no applicable :
https://devtalk.nvidia.com/default/topic/929186/jetson-tx1/jetson-tx1-kernel-compilation/
Thank you in advance,
Khang
