What do you mean by setting interfaces to IB mode? For NCCL you just need to ensure correct interface assignment in NCCL_SOCKET_IFNAME and proper RoCE interface in NCCL_IB_HCA (and having NCCL_IB_DISABLE=0).
The rest is to make sure necessary libraries are present - for example, NCCL might be installed, but rdma-core not, so it won’t use RDMA/IB and will fall back to Eth - which was happening in my case inside the docker container.
And another one is to make sure that infiniband devices are visible inside docker - you can pass /dev/infiniband (which he does) or just use privileged container (which I did, because I wasn’t sure if I needed to pass anything else in addition).
If all this is taken care of, NCCL will be able to use IB.
