Hi all,
Anyone had success installing cuda on opensuse leap 15? There is only a repo available for version 42.3.
I tried to use it and the installation seems to work ok, until I get to the post-installation and verification steps. I have successfully compiled the samples as specified in the doc. I have a NVidia GeForce GTX 860M and it was working well under OpenSuse Leap 42.3.
Any help would be greatly appreciated!
$ nvidia-persistenced --verbose
nvidia-persistenced failed to initialize. Check syslog for more details.
$ nvidia-smi
Failed to initialize NVML: Driver/library version mismatch
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
From the doc:
If a CUDA-capable device and the CUDA Driver are installed but deviceQuery reports that no CUDA-capable devices are present, this likely means that the /dev/nvidia* files are missing or have the wrong permissions.
The related files in /dev:
$ ls /dev/nvidia*
crw-rw----+ 1 root video 195, 0 Aug 27 13:04 /dev/nvidia0
crw-rw----+ 1 root 33 195, 255 Aug 27 13:04 /dev/nvidiactl
crw-rw-rw- 1 root root 195, 254 Aug 27 13:04 /dev/nvidia-modeset
crw-rw-rw-+ 1 root root 243, 0 Aug 27 13:04 /dev/nvidia-uvm
crw-rw-rw- 1 root root 243, 1 Aug 27 14:13 /dev/nvidia-uvm-tools
These are the drivers version:
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 390.77 Tue Jul 10 18:28:52 PDT 2018
GCC version: gcc version 7.3.1 20180323 [gcc-7-branch revision 258812] (SUSE Linux)
$ nvcc -V
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Tue_Jun_12_23:07:04_CDT_2018
Cuda compilation tools, release 9.2, V9.2.148
I’ve these installed from nvidia:
$ sudo zypper se --installed nvidia
Loading repository data...
Reading installed packages...
S | Name | Summary | Type
i+ | nvidia-computeG04 | NVIDIA driver for computing with GPGPU | package
i+ | nvidia-gfxG04-kmp-default | NVIDIA graphics driver kernel module for GeForce 400 series and newer | package
i+ | nvidia-glG04 | NVIDIA OpenGL libraries for OpenGL acceleration | package
i+ | x11-video-nvidiaG04 | NVIDIA graphics driver for GeForce 400 series and newer | package
And these for cuda:
$ sudo zypper se --installed cuda
i+ | cuda | CUDA meta-package | package
i | cuda-9-2 | CUDA 9.2 meta-package | package
i | cuda-command-line-tools-9-2 | CUDA command-line tools | package
i | cuda-compiler-9-2 | CUDA core tools | package
i | cuda-cublas-9-2 | CUBLAS native runtime libraries | package
i | cuda-cublas-dev-9-2 | CUBLAS native dev links, headers | package
i | cuda-cudart-9-2 | CUDA Runtime native runtime libraries | package
i | cuda-cudart-dev-9-2 | CUDA Runtime native dev links, headers | package
i | cuda-cufft-9-2 | CUFFT native runtime libraries | package
i | cuda-cufft-dev-9-2 | CUFFT native dev links, headers | package
i | cuda-cuobjdump-9-2 | CUDA cuobjdump | package
i | cuda-cupti-9-2 | CUDA Profiling Tools Interface | package
i | cuda-curand-9-2 | CURAND native runtime libraries | package
i | cuda-curand-dev-9-2 | CURAND native dev links, headers | package
i | cuda-cusolver-9-2 | CUSOLVER native runtime libraries | package
i | cuda-cusolver-dev-9-2 | CUSOLVER native dev links, headers | package
i | cuda-cusparse-9-2 | CUSPARSE native runtime libraries | package
i | cuda-cusparse-dev-9-2 | CUSPARSE native dev links, headers | package
i | cuda-demo-suite-9-2 | Set of pre-built demos using CUDA | package
i | cuda-documentation-9-2 | CUDA documentation | package
i | cuda-driver-dev-9-2 | CUDA Driver native dev stub library | package
i | cuda-drivers | CUDA Driver meta-package | package
i | cuda-gdb-9-2 | CUDA debugger API | package
i | cuda-gpu-library-advisor-9-2 | CUDA GPU Library Advisor | package
i | cuda-libraries-9-2 | CUDA Libraries 9.2 meta-package | package
i | cuda-libraries-dev-9-2 | CUDA Libraries 9.2 development meta-package | package
i | cuda-license-9-2 | CUDA licenses | package
i | cuda-memcheck-9-2 | CUDA Memcheck | package
i | cuda-misc-headers-9-2 | CUDA miscellaneous headers | package
i | cuda-npp-9-2 | NPP native runtime libraries | package
i | cuda-npp-dev-9-2 | NPP native dev links, headers | package
i | cuda-nsight-9-2 | CUDA nsight | package
i | cuda-nvcc-9-2 | CUDA nvcc | package
i | cuda-nvdisasm-9-2 | CUDA disassembler | package
i | cuda-nvgraph-9-2 | NVGRAPH native runtime libraries | package
i | cuda-nvgraph-dev-9-2 | NVGRAPH native dev links, headers | package
i | cuda-nvml-dev-9-2 | NVML native dev links, headers. | package
i | cuda-nvprof-9-2 | CUDA Profiler tools | package
i | cuda-nvprune-9-2 | CUDA nvprune | package
i | cuda-nvrtc-9-2 | NVRTC native runtime libraries | package
i | cuda-nvrtc-dev-9-2 | NVRTC native dev links, headers | package
i | cuda-nvtx-9-2 | CUDA NVIDIA Tools Extension | package
i | cuda-nvvp-9-2 | CUDA nvvp | package
i+ | cuda-repo-opensuse423 | cuda repository configuration files | package
i | cuda-runtime-9-2 | CUDA Runtime 9.2 meta-package | package
i | cuda-samples-9-2 | Contains an extensive set of example CUDA programs | package
i | cuda-toolkit-9-2 | CUDA Toolkit 9.2 meta-package | package
i | cuda-tools-9-2 | CUDA tools | package
i | cuda-visual-tools-9-2 | CUDA visual tools | package
