This is a question about GStreamer in general. A plugin guide of GStreamer is available, but when it comes to building a pipeline, your best friend would be gst-inspect.
For example, nvv4l2decoder is inspected as follow.
$ gst-inspect-1.0 nvv4l2decoder
Factory Details:
Rank primary + 11 (267)
Long-name NVIDIA v4l2 video decoder
Klass Codec/Decoder/Video
Description Decode video streams via V4L2 API
Author Nicolas Dufresne <nicolas.dufresne@collabora.com>, Viranjan Pagar <vpagar@nvidia.com>
Plugin Details:
Name nvvideo4linux2
Description Nvidia elements for Video 4 Linux
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
Version 1.14.0
License LGPL
Source module nvvideo4linux2
Binary package nvvideo4linux2
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoDecoder
+----GstNvV4l2VideoDec
+----nvv4l2decoder
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
SINK template: 'sink'
Capabilities:
image/jpeg
video/x-h264
stream-format: { (string)byte-stream }
alignment: { (string)au }
video/x-h265
video/mpeg
mpegversion: 4
systemstream: false
parsed: true
video/mpeg
mpegversion: [ 1, 2 ]
systemstream: false
parsed: true
video/x-divx
divxversion: [ 4, 5 ]
video/x-vp8
video/x-vp9
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvv4l2decoder0"
parent : The parent of the object
Object of type "GstObject"
device : Device location
flags: readable
String. Default: "/dev/nvhost-nvdec"
device-name : Name of the device
flags: Opening in BLOCKING MODE
readable
String. Default: ""
device-fd : File descriptor of the device
flags: readable
Integer. Range: -1 - 2147483647 Default: -1
output-io-mode : Output side I/O mode (matches sink pad)
Enum "GstNvV4l2DecOutputIOMode" Default: 0, "auto"
(0): auto - GST_V4L2_IO_AUTO
(2): mmap - GST_V4L2_IO_MMAP
(3): userptr - GST_V4L2_IO_USERPTR
capture-io-mode : Capture I/O mode (matches src pad)
Enum "GstNvV4l2DecCaptureIOMode" Default: 0, "auto"
extra-controls : Extra v4l2 controls (CIDs) for the device
Boxed pointer of type "GstStructure"
skip-frames : Type of frames to skip during decoding
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Enum "SkipFrame" Default: 0, "decode_all"
(0): decode_all - Decode all frames
(1): decode_non_ref - Decode non-ref frames
(2): decode_key - decode key frames
drop-frame-interval : Interval to drop the frames,ex: value of 5 means every 5th frame will be given by decoder, rest all dropped
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 30 Default: 0
num-extra-surfaces : Additional number of surfaces in addition to min decode surfaces given by the v4l2 driver
Unsigned Integer. Range: 0 - 24 Default: 1
disable-dpb : Set to disable DPB buffer for low latency
Boolean. Default: false
enable-full-frame : Whether or not the data is full framed
enable-frame-type-reporting: Set to enable frame type reporting
enable-error-check : Set to enable error check
enable-max-performance: Set to enable max performance
mjpeg : Set to open MJPEG block
bufapi-version : Set to use new buf API
And, xvimagesink.
$ gst-inspect-1.0 xvimagesink
Factory Details:
Rank primary (256)
Long-name Video sink
Klass Sink/Video
Description A Xv based videosink
Author Julien Moutte <julien@moutte.net>
Plugin Details:
Name xvimagesink
Description XFree86 video output plugin using Xv extension
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstxvimagesink.so
Version 1.14.1
License LGPL
Source module gst-plugins-base
Source release date 2018-05-17
Binary package GStreamer Base Plugins (Ubuntu)
Origin URL https://launchpad.net/distros/ubuntu/+source/gst-plugins-base1.0
GObject
+----GstObject
+----GstElement
+----GstBaseSink
+----GstVideoSink
+----GstXvImageSink
Implemented Interfaces:
GstNavigation
GstVideoOverlay
GstColorBalance
Pad Templates:
Capabilities:
video/x-raw
Pads:
SINK: 'sink'
Element Properties:
String. Default: "xvimagesink0"
sync : Sync on the clock
Boolean. Default: true
max-lateness : Maximum number of nanoseconds that a buffer can be late before it is dropped (-1 unlimited)
Integer64. Range: -1 - 9223372036854775807 Default: 20000000
qos : Generate Quality-of-Service events upstream
async : Go asynchronously to PAUSED
ts-offset : Timestamp offset in nanoseconds
Integer64. Range: -9223372036854775808 - 9223372036854775807 Default: 0
enable-last-sample : Enable the last-sample property
last-sample : The last sample received in the sink
flags: readable
Boxed pointer of type "GstSample"
blocksize : Size in bytes to pull per buffer (0 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
render-delay : Additional render delay of the sink in nanoseconds
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
throttle-time : The time to keep between rendered buffers (0 = disabled)
max-bitrate : The maximum bits per second to render (0 = disabled)
show-preroll-frame : Whether to render video frames during preroll
contrast : The contrast of the video
Integer. Range: -1000 - 1000 Default: 0
brightness : The brightness of the video
hue : The hue of the video
saturation : The saturation of the video
display : X Display name
String. Default: null
synchronous : When enabled, runs the X display in synchronous mode. (unrelated to A/V sync, used only for debugging)
pixel-aspect-ratio : The pixel aspect ratio of the device
force-aspect-ratio : When enabled, scaling will respect original aspect ratio
handle-events : When enabled, XEvents will be selected and handled
device : The number of the video adaptor
String. Default: "0"
device-name : The name of the video adaptor
flags: readable
handle-expose : When enabled, the current frame will always be drawn in response to X Expose events
double-buffer : Whether to double-buffer the output
autopaint-colorkey : Whether to autofill overlay with colorkey
colorkey : Color to use for the overlay mask
Integer. Range: -2147483648 - 2147483647 Default: 526352
draw-borders : Draw black borders to fill unused area in force-aspect-ratio mode
window-width : Width of the window
flags: readable
window-height : Height of the window
flags: readable
render-rectangle : The render rectangle ('<x, y, width, height>')
flags: writable
GstValueArray of GValues of type "gint" Write only
An element of GStremer has zero or more sink(input) and source(output) pads. And if one element can be linked to another is up to their capabilities. If one capability matches to another one, it is linked. Otherwise, it is not. This gets complicated if a pad is dynamically created. But for now, just consider a static pad(Availability: Always).
Now, take a look at the sink’s capability of xvimagesink, which is:
video/x-raw
And let’s compare it with the source’s capability of nvv4l2decoder.
This looks the same, except for the memory. nvv4l2decoder passes an output buffer in NVMM, which means on a GPU memory here. But xvimagesink needs a buffer on a main memory. That’s why your pipeline fails.
This is a hardware accelerated version of your pipeline.
$ gst-launch-1.0 filesrc location=/home/lalita/Downloads/training-20190708T173445Z-001/training/0/0.h264 ! h264parse ! nvv4l2decoder ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=RGBA" ! nvegltransform ! nveglglessink sync=False
Try inspecting unknown elements, and see how they are connected with the gst-launch. Sometimes it doesn’t work as expected even if they look identical from capabilities.
