installing netcdf
Dear.
I wonder that the netcdf is installed in my computer.
OS:Fedora 9
complier : pgf 7.1.6_x86_64
netcdf : 3.6.2
command is descrpit below;
env CC=pgcc CFLAGS=“-O2 -Msignextend -V” FC=pgf90 F90=pgf90 FFLAGS=“-O2 -w -V”
CXX=pgCC CPPFLAGS=“-DNDEBUG -DpgiFortran” ./configure -prefix=/usr/local/netcdf>& config.log
configure: netCDF 3.6.2
checking build system type… x86_64-unknown-linux-gnu
checking host system type… x86_64-unknown-linux-gnu
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
configure: checking user options
checking whether CXX is set to ‘’… no
checking whether FC is set to ‘’… no
checking whether F90 is set to ‘’… no
checking whether documentation is to be installed… no
checking whether Fortran compiler(s) should be tested during configure… yes
checking whether configure should try to set compiler flags… yes
checking whether FFIO will be used… no
checking whether to skip C++, F77, or F90 APIs if compiler is broken… yes
checking whether only the C library is desired… no
checking whether examples should be built… yes
checking whether F77 API is desired… yes
checking whether F90 API is desired… yes
checking whether fortran type sizes should be checked… yes
checking whether C API is desired… yes
checking where to get netCDF C-only library for separate fortran libraries…
checking whether CXX API is desired… yes
checking whether v2 netCDF API should be built… yes
checking whether the ncgen/ncdump should be built… yes
checking whether large file (> 2GB) tests should be run… no
checking whether extreme numbers should be used in tests… yes
checking where to put large temp files if large file tests are run… .
checking whether a win32 DLL is desired… no
checking whether separate fortran libs are desired… no
configure: finding C compiler
checking for xlc… no
checking for cc… cc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether cc accepts -g… yes
checking for cc option to accept ISO C89… none needed
checking for style of include used by make… GNU
checking dependency style of cc… gcc3
checking whether cc understands -c and -o together… yes
checking for an ANSI C-conforming const… yes
configure: finding Fortran compiler (will not be used if Fortran API is not desired)
checking for xlf90… no
checking for fort… no
checking for xlf95… no
checking for ifort… no
checking for ifc… no
checking for efc… no
checking for pgf95… pgf95
checking whether we are using the GNU Fortran compiler… no
checking whether pgf95 accepts -g… yes
checking for xlf… no
checking for pgf77… pgf77
checking whether we are using the GNU Fortran 77 compiler… no
checking whether pgf77 accepts -g… yes
configure: setting up Fortran 90
checking for Fortran flag to compile .f90 files… none
checking fortran 90 modules inclusion flag… -I
checking if Fortran compiler can handle Fortran-90… yes
configure: finding C++ compiler (will not be used if C++ API is not desired)
checking whether we are using the GNU C++ compiler… no
checking whether pgCC accepts -g… yes
checking dependency style of pgCC… none
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by cc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 32768
checking whether the shell understands some XSI constructs… yes
checking whether the shell understands “+=”… yes
checking for /usr/bin/ld option to reload object files… -r
checking how to recognise dependent libraries… pass_all
checking for ar… ar
checking for strip… strip
checking for ranlib… ranlib
checking command to parse /usr/bin/nm -B output from cc object… ok
checking how to run the C preprocessor… cc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking whether we are using the GNU C++ compiler… (cached) no
checking whether pgCC accepts -g… (cached) yes
checking dependency style of pgCC… (cached) none
checking how to run the C++ preprocessor… pgCC -E
checking whether we are using the GNU Fortran 77 compiler… (cached) no
checking whether pgf77 accepts -g… (cached) yes
checking whether we are using the GNU Fortran compiler… (cached) no
checking whether pgf95 accepts -g… (cached) yes
checking for objdir… .libs
checking if cc supports -fno-rtti -fno-exceptions… no
checking for cc option to produce PIC… -fPIC -DPIC
checking if cc PIC flag -fPIC -DPIC works… yes
checking if cc static flag -static works… yes
checking if cc supports -c -o file.o… yes
checking if cc supports -c -o file.o… (cached) yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… no
checking whether to build static libraries… yes
checking whether the pgCC linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking for pgCC option to produce PIC… -fpic -DPIC
checking if pgCC PIC flag -fpic -DPIC works… yes
checking if pgCC static flag -Bstatic works… no
checking if pgCC supports -c -o file.o… yes
checking if pgCC supports -c -o file.o… (cached) yes
checking for pgf77 option to produce PIC… -fPIC
checking if pgf77 PIC flag -fPIC works… yes
checking if pgf77 static flag -static works… no
checking if pgf77 supports -c -o file.o… yes
checking if pgf77 supports -c -o file.o… (cached) yes
checking whether the pgf77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking for pgf95 option to produce PIC… -fPIC
checking if pgf95 PIC flag -fPIC works… yes
checking if pgf95 static flag -static works… no
checking if pgf95 supports -c -o file.o… yes
checking if pgf95 supports -c -o file.o… (cached) yes
checking whether the pgf95 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
configure: finding other utilities
configure: trying to set fortran flags for this platform
configure: trying to set flags for this platform
checking if _HPUX_SOURCE should be set… no
checking if Solaris -Xa option is needed… CFLAGS=-g -O2
configure: trying to set fortran 90 flags for this platform
checking if we need to add to FFLAGS for ifort compiler… FFLAGS=-g
checking if we need to set _LARGE_FILES despite results of previous tests… _LARGE_FILES=
checking for special C compiler options needed for large files… no
checking for FILE_OFFSET_BITS value needed for large files… no
configure: displaying some results
checking CPPFLAGS… -DNDEBUG -DpgiFortran
checking CC CFLAGS… cc -g -O2
checking type cc… cc is /usr/lib64/ccache/cc
checking CXX… pgCC
checking CXXFLAGS… -g
checking type pgCC… pgCC is /opt/pgi/linux86-64/7.1/bin/pgCC
checking FC… pgf95
checking FFLAGS… -g
checking type pgf95… pgf95 is /opt/pgi/linux86-64/7.1/bin/pgf95
checking F90… pgf95
checking F90FLAGS…
checking AR… ar
checking ARFLAGS…
checking type ar… ar is /usr/bin/ar
checking NM… /usr/bin/nm -B
checking NMFLAGS…
checking for /usr/bin/nm… /usr/bin/nm -B
checking nm flags…
checking for C-equivalent to Fortran routine “SUB”… sub
checking for Fortran “byte”… yes
checking for Fortran “integer2"… yes
checking if Fortran “byte” is C “signed char”… yes
checking if Fortran “byte” is C “short”… no
checking if Fortran “byte” is C “int”… no
checking if Fortran “byte” is C “long”… no
checking if Fortran "integer
2” is C “short”… yes
checking if Fortran “integer2" is C “int”… no
2” is C “long”… no
checking if Fortran “integer” is C “int”… yes
checking if Fortran “real” is C “float”… yes
checking if Fortran “doubleprecision” is C “double”… yes
checking for Fortran-equivalent to netCDF “byte”… byte
checking for Fortran-equivalent to netCDF “short”… integer*2
checking if Fortran 90 compiler capitalizes .mod filenames… no
configure: checking types, headers, and functions
checking for stdlib.h… (cached) yes
checking for sys/types.h… (cached) yes
checking for strlcat… no
checking for strerror… yes
checking for working alloca.h… yes
checking for alloca… yes
checking for struct stat.st_blksize… yes
checking for IEEE floating point format… yes
checking for size_t… yes
checking for off_t… yes
checking for ssize_t… yes
checking for ptrdiff_t… yes
checking for uchar… no
checking whether char is unsigned… no
checking whether byte ordering is bigendian… no
checking for short… yes
checking size of short… 2
checking for int… yes
checking size of int… 4
checking for long… yes
checking size of long… 8
checking for float… yes
checking size of float… 4
checking for double… yes
checking size of double… 8
checking for off_t… (cached) yes
checking size of off_t… 8
checking for size_t… (cached) yes
checking size of size_t… 8
checking for manual-page index command…
checking binary distribution directory… /home/ftp/pub/binary/dummy_system
configure: generating header files and makefiles
configure: creating ./config.status
config.status: creating Makefile
config.status: creating man/Makefile
config.status: creating fortran/Makefile
config.status: creating libsrc/Makefile
config.status: creating nctest/Makefile
config.status: creating nc_test/Makefile
config.status: creating ncdump/Makefile
config.status: creating ncgen/Makefile
config.status: creating nf_test/Makefile
config.status: creating cxx/Makefile
config.status: creating f90/Makefile
config.status: creating examples/Makefile
config.status: creating examples/C/Makefile
config.status: creating examples/CDL/Makefile
config.status: creating examples/CXX/Makefile
config.status: creating examples/F90/Makefile
config.status: creating examples/F77/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating fortran/nfconfig1.inc
config.status: fortran/nfconfig1.inc is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
17: warning: variable “me” was declared but never
referenced
choke me
1 error detected in the compilation of “conftest.cpp”.
configure:5588: $? = 2
configure: failed program was:
| /* confdefs.h. /
| define PACKAGE_NAME “netCDF”
| define PACKAGE_TARNAME “netcdf”
| define PACKAGE_VERSION “3.6.2”
| define PACKAGE_STRING “netCDF 3.6.2”
| define PACKAGE_BUGREPORT "> support@unidata.ucar.edu> "
| define PACKAGE “netcdf”
| define VERSION “3.6.2”
| define USE_EXTREME_NUMBERS 1
| define TEMP_LARGE $TEMP_LARGE
end confdefs.h. /
| int
| main ()
| #ifndef GNUC
| choke me
| endif
| return 0;
configure:5605: result: no
configure:5610: checking whether pgCC accepts -g
configure:5640: pgCC -c -g -DNDEBUG -DpgiFortran conftest.cpp >&5
configure:5646: $? = 0
configure:5745: result: yes
configure:5770: checking dependency style of pgCC
configure:5860: result: none
configure:6366: checking for a sed that does not truncate output
configure:6445: result: /bin/sed
configure:6463: checking for grep that handles long lines and -e
configure:6537: result: /bin/grep
configure:6542: checking for egrep
configure:6620: result: /bin/grep -E
configure:6625: checking for fgrep
configure:6703: result: /bin/grep -F
configure:6738: checking for ld used by cc
configure:6805: result: /usr/bin/ld
configure:6814: checking if the linker (/usr/bin/ld) is GNU ld
configure:6829: result: yes
configure:6842: checking for BSD- or MS-compatible name lister (nm)
configure:6891: result: /usr/bin/nm -B
configure:7013: checking the name lister (/usr/bin/nm -B) interface
configure:7020: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:7023: /usr/bin/nm -B “conftest.o”
configure:7026: output
0000000000000000 B some_variable
configure:7033: result: BSD nm
configure:7036: checking whether ln -s works
configure:7040: result: yes
configure:7048: checking the maximum length of command line arguments
configure:7162: result: 32768
configure:7180: checking whether the shell understands some XSI constructs
configure:7188: result: yes
configure:7192: checking whether the shell understands “+=”
configure:7198: result: yes
configure:7233: checking for /usr/bin/ld option to reload object files
configure:7240: result: -r
configure:7267: checking how to recognise dependent libraries
configure:7451: result: pass_all
configure:7511: checking for ar
configure:7527: found /usr/bin/ar
configure:7538: result: ar
configure:7620: checking for strip
configure:7636: found /usr/bin/strip
configure:7647: result: strip
configure:7723: checking for ranlib
configure:7739: found /usr/bin/ranlib
configure:7750: result: ranlib
configure:7844: checking command to parse /usr/bin/nm -B output from cc object
configure:7960: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:7963: $? = 0
configure:7967: /usr/bin/nm -B conftest.o | sed -n -e 's/^.
[ ]([ABCDGIRSTW][ABCDGIRSTW])[ ][ ]([_A-Za-z][_A-Za-z0-9])$/\1 \2 \2/p’ > conftest.nm
configure:7970: $? = 0
configure:8024: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c conftstm.o >&5
configure:8027: $? = 0
configure:8065: result: ok
configure:8154: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:8157: $? = 0
configure:8297: checking how to run the C preprocessor
configure:8337: cc -E -DNDEBUG -DpgiFortran conftest.c
configure:8343: $? = 0
configure:8374: cc -E -DNDEBUG -DpgiFortran conftest.c
conftest.c:12:28: error: ac_nonexistent.h: No such file or directory
configure:8380: $? = 1
confdefs.h. /
end confdefs.h. /
| include <ac_nonexistent.h>
configure:8413: result: cc -E
configure:8442: cc -E -DNDEBUG -DpgiFortran conftest.c
configure:8448: $? = 0
configure:8479: cc -E -DNDEBUG -DpgiFortran conftest.c
configure:8485: $? = 1
confdefs.h. /
end confdefs.h. */
configure:8523: checking for ANSI C header files
configure:8553: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:8559: $? = 0
configure:8658: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:8661: $? = 0
configure:8667: ./conftest
configure:8670: $? = 0
configure:8687: result: yes
configure:8711: checking for sys/types.h
configure:8732: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:8738: $? = 0
configure:8754: result: yes
configure:8711: checking for sys/stat.h
configure:8711: checking for stdlib.h
configure:8711: checking for string.h
configure:8711: checking for memory.h
configure:8711: checking for strings.h
configure:8711: checking for inttypes.h
configure:8711: checking for stdint.h
configure:8711: checking for unistd.h
configure:8770: checking for dlfcn.h
configure:8791: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:8797: $? = 0
configure:8813: result: yes
configure:8942: checking for C++ compiler version
configure:8949: pgCC --version >&5
pgCC 7.1-6 64-bit target on x86-64 Linux -tp p7-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2007, STMicroelectronics, Inc. All Rights Reserved.
configure:8952: $? = 0
configure:8959: pgCC -v >&5
pgCC-Warning-No files to process
configure:8962: $? = 0
configure:8969: pgCC -V >&5
configure:8972: $? = 0
configure:8975: checking whether we are using the GNU C++ compiler
configure:9027: result: no
configure:9032: checking whether pgCC accepts -g
configure:9167: result: yes
configure:9192: checking dependency style of pgCC
configure:9282: result: none
configure:9307: checking how to run the C++ preprocessor
configure:9343: pgCC -E -DNDEBUG -DpgiFortran conftest.cpp
configure:9349: $? = 0
configure:9380: pgCC -E -DNDEBUG -DpgiFortran conftest.cpp
“conftest.cpp”, line 23: error: could not open source file “ac_nonexistent.h”
configure:9386: $? = 2
| /* confdefs.h. /
| define STDC_HEADERS 1
| define HAVE_SYS_TYPES_H 1
| define HAVE_SYS_STAT_H 1
| define HAVE_STDLIB_H 1
| define HAVE_STRING_H 1
| define HAVE_MEMORY_H 1
| define HAVE_STRINGS_H 1
| define HAVE_INTTYPES_H 1
| define HAVE_STDINT_H 1
| define HAVE_UNISTD_H 1
| define HAVE_DLFCN_H 1
end confdefs.h. */
configure:9419: result: pgCC -E
configure:9448: pgCC -E -DNDEBUG -DpgiFortran conftest.cpp
configure:9454: $? = 0
configure:9485: pgCC -E -DNDEBUG -DpgiFortran conftest.cpp
configure:9491: $? = 2
| /* confdefs.h. /
end confdefs.h. */
configure:9642: checking for Fortran 77 compiler version
configure:9649: pgf77 --version >&5
pgf77-Error-Unknown switch: --version
configure:9652: $? = 1
configure:9659: pgf77 -v >&5
pgf77-Warning-No files to process
configure:9662: $? = 0
configure:9669: pgf77 -V >&5
pgf77 7.1-6 64-bit target on x86-64 Linux -tp p7-64
configure:9672: $? = 0
configure:9680: checking whether we are using the GNU Fortran 77 compiler
configure:9722: result: no
configure:9728: checking whether pgf77 accepts -g
configure:9767: result: yes
configure:9910: checking for Fortran compiler version
configure:9917: pgf95 --version >&5
pgf95-Error-Unknown switch: --version
configure:9920: $? = 1
configure:9927: pgf95 -v >&5
pgf95-Warning-No files to process
configure:9930: $? = 0
configure:9937: pgf95 -V >&5
pgf95 7.1-6 64-bit target on x86-64 Linux -tp p7-64
configure:9940: $? = 0
configure:9948: checking whether we are using the GNU Fortran compiler
configure:9990: result: no
configure:9996: checking whether pgf95 accepts -g
configure:10035: result: yes
configure:10115: checking for objdir
configure:10130: result: .libs
configure:10422: checking if cc supports -fno-rtti -fno-exceptions
configure:10440: cc -c -g -O2 -DNDEBUG -DpgiFortran -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option “-fno-rtti” is valid for C++/ObjC++ but not for C
configure:10444: $? = 0
configure:10457: result: no
configure:10477: checking for cc option to produce PIC
configure:10730: result: -fPIC -DPIC
configure:10742: checking if cc PIC flag -fPIC -DPIC works
configure:10760: cc -c -g -O2 -DNDEBUG -DpgiFortran -fPIC -DPIC -DPIC conftest.c >&5
configure:10764: $? = 0
configure:10777: result: yes
configure:10801: checking if cc static flag -static works
configure:10829: result: yes
configure:10844: checking if cc supports -c -o file.o
configure:10865: cc -c -g -O2 -DNDEBUG -DpgiFortran -o out/conftest2.o conftest.c >&5
configure:10869: $? = 0
configure:10891: result: yes
configure:10899: checking if cc supports -c -o file.o
configure:10946: result: yes
configure:10979: checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:12050: result: yes
configure:12284: checking dynamic linker characteristics
configure:12895: result: GNU/Linux ld.so
configure:12990: checking how to hardcode library paths into programs
configure:13015: result: immediate
configure:13828: checking whether stripping libraries is possible
configure:13833: result: yes
configure:13868: checking if libtool supports shared libraries
configure:13870: result: yes
configure:13873: checking whether to build shared libraries
configure:13894: result: no
configure:13897: checking whether to build static libraries
configure:13901: result: yes
configure:14196: checking whether the pgCC linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:15185: result: yes
configure:15213: pgCC -c -g -DNDEBUG -DpgiFortran conftest.cpp >&5
configure:15216: $? = 0
configure:15369: checking for pgCC option to produce PIC
configure:15672: result: -fpic -DPIC
configure:15681: checking if pgCC PIC flag -fpic -DPIC works
configure:15699: pgCC -c -g -DNDEBUG -DpgiFortran -fpic -DPIC -DPIC conftest.cpp >&5
configure:15703: $? = 0
configure:15716: result: yes
configure:15737: checking if pgCC static flag -Bstatic works
conftest.cpp:
configure:15765: result: no
configure:15777: checking if pgCC supports -c -o file.o
configure:15798: pgCC -c -g -DNDEBUG -DpgiFortran -o out/conftest2.o conftest.cpp >&5
configure:15802: $? = 0
configure:15824: result: yes
configure:15829: checking if pgCC supports -c -o file.o
configure:15876: result: yes
configure:15906: checking whether the pgCC linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:15931: result: yes
configure:16066: checking dynamic linker characteristics
configure:16677: result: GNU/Linux ld.so
configure:16721: checking how to hardcode library paths into programs
configure:16746: result: immediate
configure:16879: checking if libtool supports shared libraries
configure:16881: result: yes
configure:16884: checking whether to build shared libraries
configure:16904: result: no
configure:16907: checking whether to build static libraries
configure:16911: result: yes
configure:16925: checking for pgf77 option to produce PIC
configure:17178: result: -fPIC
configure:17187: checking if pgf77 PIC flag -fPIC works
configure:17205: pgf77 -c -g -fPIC conftest.f >&5
configure:17209: $? = 0
configure:17222: result: yes
configure:17243: checking if pgf77 static flag -static works
configure:17271: result: no
configure:17283: checking if pgf77 supports -c -o file.o
configure:17304: pgf77 -c -g -o out/conftest2.o conftest.f >&5
configure:17308: $? = 0
configure:17330: result: yes
configure:17335: checking if pgf77 supports -c -o file.o
configure:17382: result: yes
configure:17412: checking whether the pgf77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:18463: result: yes
configure:18598: checking dynamic linker characteristics
configure:19209: result: GNU/Linux ld.so
configure:19253: checking how to hardcode library paths into programs
configure:19278: result: immediate
configure:19403: checking if libtool supports shared libraries
configure:19405: result: yes
configure:19408: checking whether to build shared libraries
configure:19428: result: no
configure:19431: checking whether to build static libraries
configure:19435: result: yes
configure:19461: pgf95 -c -g conftest.f90 >&5
configure:19464: $? = 0
configure:19573: checking for pgf95 option to produce PIC
configure:19826: result: -fPIC
configure:19835: checking if pgf95 PIC flag -fPIC works
configure:19853: pgf95 -c -g -fPIC conftest.f90 >&5
configure:19857: $? = 0
configure:19870: result: yes
configure:19891: checking if pgf95 static flag -static works
configure:19919: result: no
configure:19931: checking if pgf95 supports -c -o file.o
configure:19952: pgf95 -c -g -o out/conftest2.o conftest.f90 >&5
configure:19956: $? = 0
configure:19978: result: yes
configure:19983: checking if pgf95 supports -c -o file.o
configure:20030: result: yes
configure:20060: checking whether the pgf95 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:21111: result: yes
configure:21246: checking dynamic linker characteristics
configure:21857: result: GNU/Linux ld.so
configure:21901: checking how to hardcode library paths into programs
configure:21926: result: immediate
configure:21973: finding other utilities
configure:21989: checking for a BSD-compatible install
configure:22045: result: /usr/bin/install -c
configure:22058: trying to set fortran flags for this platform
configure:22103: trying to set flags for this platform
configure:22108: checking if HPUX_SOURCE should be set
configure:22124: result: no
configure:22129: checking if Solaris -Xa option is needed
configure:22142: result: CFLAGS=-g -O2
configure:22147: trying to set fortran 90 flags for this platform
configure:22150: checking if we need to add to FFLAGS for ifort compiler
configure:22158: result: FFLAGS=-g
configure:22168: checking if we need to set LARGE_FILES despite results of previous tests
configure:22199: result: LARGE_FILES=
configure:22209: checking for special C compiler options needed for large files
configure:22302: result: no
configure:22308: checking for FILE_OFFSET_BITS value needed for large files
configure:22343: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:22349: $? = 0
configure:22417: result: no
configure:22553: displaying some results
configure:22559: checking CPPFLAGS
configure:22561: result: -DNDEBUG -DpgiFortran
configure:22563: checking CC CFLAGS
configure:22565: result: cc -g -O2
configure:22568: checking type cc
configure:22570: result: cc is /usr/lib64/ccache/cc
configure:22573: checking CXX
configure:22576: result: pgCC
configure:22578: checking CXXFLAGS
configure:22580: result: -g
configure:22583: checking type pgCC
configure:22585: result: pgCC is /opt/pgi/linux86-64/7.1/bin/pgCC
configure:22592: checking FC
configure:22595: result: pgf95
configure:22597: checking FFLAGS
configure:22599: result: -g
configure:22602: checking type pgf95
configure:22604: result: pgf95 is /opt/pgi/linux86-64/7.1/bin/pgf95
configure:22611: checking F90
configure:22614: result: pgf95
configure:22616: checking F90FLAGS
configure:22618: result:
configure:22621: checking type pgf95
configure:22623: result: pgf95 is /opt/pgi/linux86-64/7.1/bin/pgf95
configure:22630: checking AR
configure:22633: result: ar
configure:22635: checking ARFLAGS
configure:22637: result:
configure:22640: checking type ar
configure:22642: result: ar is /usr/bin/ar
configure:22649: checking NM
configure:22652: result: /usr/bin/nm -B
configure:22654: checking NMFLAGS
configure:22656: result:
configure:22723: checking for /usr/bin/nm
configure:22750: result: /usr/bin/nm -B
configure:22763: checking nm flags
configure:22768: result:
configure:22780: checking for C-equivalent to Fortran routine “SUB”
configure:22787: pgf95 -c -g conftest.f
configure:22790: $? = 0
configure:22802: result: sub
configure:22824: checking for Fortran “byte”
configure:22832: pgf95 -c -g conftest.f
configure:22835: $? = 0
configure:22837: result: yes
configure:22855: checking for Fortran “integer*2”
configure:22863: pgf95 -c -g conftest.f
configure:22866: $? = 0
configure:22868: result: yes
configure:22895: checking if Fortran “byte” is C “signed char”
configure:22905: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
conftest.c: In function 'sub
conftest.c:4: warning: incompatible implicit declaration of built-in function ‘exit’
configure:22908: $? = 0
configure:22911: pgf95 -g -c conftestf.f
configure:22914: $? = 0
configure:22917: pgf95 -o conftest -g conftestf.o conftest.o
configure:22920: $? = 0
configure:22923: ./conftest
configure:22926: $? = 0
configure:22928: result: yes
configure:22968: checking if Fortran “byte” is C “short”
configure:22978: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:22981: $? = 0
configure:22984: pgf95 -g -c conftestf.f
configure:22987: $? = 0
configure:22990: pgf95 -o conftest -g conftestf.o conftest.o
configure:22993: $? = 0
configure:22996: ./conftest
configure:22999: $? = 1
configure:23012: result: no
configure:23041: checking if Fortran “byte” is C “int”
configure:23051: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23054: $? = 0
configure:23057: pgf95 -g -c conftestf.f
configure:23060: $? = 0
configure:23063: pgf95 -o conftest -g conftestf.o conftest.o
configure:23066: $? = 0
configure:23069: ./conftest
configure:23072: $? = 1
configure:23085: result: no
configure:23114: checking if Fortran “byte” is C “long”
configure:23124: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
conftest.c: In function ‘sub_’:
configure:23127: $? = 0
configure:23130: pgf95 -g -c conftestf.f
configure:23133: $? = 0
configure:23136: pgf95 -o conftest -g conftestf.o conftest.o
configure:23139: $? = 0
configure:23142: ./conftest
configure:23145: $? = 1
configure:23158: result: no
configure:23191: checking if Fortran “integer2" is C “short”
configure:23201: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23204: $? = 0
configure:23207: pgf95 -g -c conftestf.f
configure:23210: $? = 0
configure:23213: pgf95 -o conftest -g conftestf.o conftest.o
configure:23216: $? = 0
configure:23219: ./conftest
configure:23222: $? = 0
configure:23224: result: yes
configure:23264: checking if Fortran "integer
2” is C “int”
configure:23274: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23277: $? = 0
configure:23280: pgf95 -g -c conftestf.f
configure:23283: $? = 0
configure:23286: pgf95 -o conftest -g conftestf.o conftest.o
configure:23289: $? = 0
configure:23292: ./conftest
configure:23295: $? = 1
configure:23308: result: no
configure:23337: checking if Fortran "integer2" is C “long”
configure:23347: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23350: $? = 0
configure:23353: pgf95 -g -c conftestf.f
configure:23356: $? = 0
configure:23359: pgf95 -o conftest -g conftestf.o conftest.o
configure:23362: $? = 0
configure:23365: ./conftest
configure:23368: $? = 1
configure:23381: result: no
configure:23412: checking if Fortran “integer” is C “int”
configure:23422: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23425: $? = 0
configure:23428: pgf95 -g -c conftestf.f
configure:23431: $? = 0
configure:23434: pgf95 -o conftest -g conftestf.o conftest.o
configure:23437: $? = 0
configure:23440: ./conftest
configure:23443: $? = 0
configure:23445: result: yes
configure:23485: checking if Fortran “real” is C “float”
configure:23495: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23498: $? = 0
configure:23501: pgf95 -g -c conftestf.f
configure:23504: $? = 0
configure:23507: pgf95 -o conftest -g conftestf.o conftest.o
configure:23510: $? = 0
configure:23513: ./conftest
configure:23516: $? = 0
configure:23518: result: yes
configure:23558: checking if Fortran “doubleprecision” is C “double”
configure:23568: cc -c -DNDEBUG -DpgiFortran -g -O2 conftest.c
configure:23571: $? = 0
configure:23574: pgf95 -g -c conftestf.f
configure:23577: $? = 0
configure:23580: pgf95 -o conftest -g conftestf.o conftest.o
configure:23583: $? = 0
configure:23586: ./conftest
configure:23589: $? = 0
configure:23591: result: yes
configure:23625: checking for Fortran-equivalent to netCDF “byte”
configure:23633: pgf95 -c -g conftest.f
configure:23636: $? = 0
configure:23647: result: byte
configure:23653: checking for Fortran-equivalent to netCDF “short”
configure:23661: pgf95 -c -g conftest.f
configure:23664: $? = 0
configure:23675: result: integer
2
configure:23742: checking if Fortran 90 compiler capitalizes .mod filenames
configure:23749: pgf95 conftest.f90 >&5
/opt/pgi/linux86-64/7.1-6/lib/f90main.o: In function main': f90main.c:(.text+0x3c): undefined reference to MAIN_’
configure:23752: $? = 2
configure:23759: result: no
configure:23782: checking types, headers, and functions
configure:23786: checking for stdlib.h
configure:23791: result: yes
configure:23927: checking for sys/types.h
configure:23932: result: yes
configure:24074: checking for strlcat
configure:24130: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
/tmp/cc4BdEqj.o: In function main': /usr/local/netcdf-3.6.2/conftest.c:67: undefined reference to strlcat’
collect2: ld returned 1 exit status
configure:24136: $? = 1
| /* confdefs.h. /
| define LT_OBJDIR “.libs/”
| define NF_INT1_T byte
| define NF_INT2_T integer
2
| define NF_INT1_IS_C_SIGNED_CHAR 1
| define NF_INT2_IS_C_SHORT 1
| define NF_INT_IS_C_INT 1
| define NF_REAL_IS_C_FLOAT 1
| define NF_DOUBLEPRECISION_IS_C_DOUBLE 1
| define NCBYTE_T byte
| define NCSHORT_T integer2
end confdefs.h. /
Define strlcat to an innocuous variant, in case <limits.h> declares strlcat.
| For example, HP-UX 11i <limits.h> declares gettimeofday. /
| define strlcat innocuous_strlcat
System header to define stub macros and hopefully few prototypes,
| which can conflict with char strlcat (); below.
| Prefer <limits.h> to <assert.h> if STDC is defined, since
| <limits.h> exists even on freestanding compilers. /
| ifdef STDC
| # include <limits.h>
| else
| # include <assert.h>
| endif
| #undef strlcat
Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. /
| ifdef __cplusplus
| extern “C”
| endif
| char strlcat ();
The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. /
| #if defined __stub_strlcat || defined stub___strlcat
| choke me
| endif
| int
| main ()
| return strlcat ();
| return 0;
configure:24154: result: no
configure:24074: checking for strerror
configure:24136: $? = 0
configure:24154: result: yes
configure:24166: checking for working alloca.h
configure:24193: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24199: $? = 0
configure:24216: result: yes
configure:24226: checking for alloca
configure:24273: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24279: $? = 0
configure:24296: result: yes
configure:24525: checking for struct stat.st_blksize
configure:24553: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24559: $? = 0
configure:24616: result: yes
configure:24633: checking for IEEE floating point format
configure:24681: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24684: $? = 0
configure:24690: ./conftest
configure:24693: $? = 0
configure:24708: result: yes
configure:24718: checking for size_t
configure:24748: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24754: $? = 0
configure:24769: result: yes
configure:24781: checking for off_t
configure:24811: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24817: $? = 0
configure:24832: result: yes
configure:24844: checking for ssize_t
configure:24874: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24880: $? = 0
configure:24895: result: yes
configure:24905: checking for ptrdiff_t
configure:24935: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:24941: $? = 0
configure:24956: result: yes
configure:24966: checking for uchar
configure:24996: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
conftest.c:73: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before 'ac__type_new
conftest.c: In function ‘main’:
conftest.c:77: error: 'ac__type_new
’ undeclared (first use in this function)
conftest.c:77: error: (Each undeclared identifier is reported only once
conftest.c:77: error: for each function it appears in.)
conftest.c:77: error: expected expression before ‘)’ token
configure:25002: $? = 1
confdefs.h. /
2
| define HAVE_STRERROR 1
| define HAVE_ALLOCA_H 1
| define HAVE_ALLOCA 1
| define HAVE_STRUCT_STAT_ST_BLKSIZE 1
| define HAVE_ST_BLKSIZE 1
| define HAVE_SSIZE_T 1
| define HAVE_PTRDIFF_T 1
end confdefs.h. */
| include <stdio.h>
| ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| endif
| ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| endif
| ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| else
| # ifdef HAVE_STDLIB_H
| # endif
| endif
| ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| endif
| ifdef HAVE_STRINGS_H
| # include <strings.h>
| endif
| ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| endif
| ifdef HAVE_STDINT_H
| # include <stdint.h>
| endif
| ifdef HAVE_UNISTD_H
| # include <unistd.h>
| endif
| typedef uchar ac__type_new
| int
| main ()
| if ((ac__type_new
) 0)
| return 0;
| if (sizeof (ac__type_new_))
| return 0;
| return 0;
configure:25017: result: no
configure:25032: checking whether char is unsigned
configure:25060: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:25066: $? = 0
configure:25081: result: no
configure:25090: checking whether byte ordering is bigendian
configure:25123: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:25129: $? = 0
configure:25161: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
conftest.c:47: error: ‘not’ undeclared (first use in this function)
conftest.c:47: error: (Each undeclared identifier is reported only once
conftest.c:47: error: for each function it appears in.)
conftest.c:47: error: expected ‘;’ before ‘big’
configure:25167: $? = 1
confdefs.h. /
2
end confdefs.h. */
| include <sys/param.h>
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
| not big endian
| endif
| return 0;
configure:25307: result: no
configure:25326: checking for short
configure:25356: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:25362: $? = 0
configure:25377: result: yes
configure:25384: checking size of short
configure:25686: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:25689: $? = 0
configure:25695: ./conftest
configure:25698: $? = 0
configure:25721: result: 2
configure:25731: checking for int
configure:25761: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:25767: $? = 0
configure:25782: result: yes
configure:25789: checking size of int
configure:26091: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26094: $? = 0
configure:26100: ./conftest
configure:26103: $? = 0
configure:26126: result: 4
configure:26136: checking for long
configure:26166: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26172: $? = 0
configure:26187: result: yes
configure:26194: checking size of long
configure:26496: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26499: $? = 0
configure:26505: ./conftest
configure:26508: $? = 0
configure:26531: result: 8
configure:26541: checking for float
configure:26571: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26577: $? = 0
configure:26592: result: yes
configure:26599: checking size of float
configure:26901: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26904: $? = 0
configure:26910: ./conftest
configure:26913: $? = 0
configure:26936: result: 4
configure:26946: checking for double
configure:26976: cc -c -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:26982: $? = 0
configure:26997: result: yes
configure:27004: checking size of double
configure:27306: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:27309: $? = 0
configure:27315: ./conftest
configure:27318: $? = 0
configure:27341: result: 8
configure:27351: checking for off_t
configure:27402: result: yes
configure:27409: checking size of off_t
configure:27711: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:27714: $? = 0
configure:27720: ./conftest
configure:27723: $? = 0
configure:27746: result: 8
configure:27756: checking for size_t
configure:27807: result: yes
configure:27814: checking size of size_t
configure:28116: cc -o conftest -g -O2 -DNDEBUG -DpgiFortran conftest.c >&5
configure:28119: $? = 0
configure:28125: ./conftest
configure:28128: $? = 0
configure:28151: result: 8
configure:28250: checking for manual-page index command
configure:28252: result:
configure:28255: checking binary distribution directory
configure:28263: result: /home/ftp/pub/binary/dummy_system
configure:28286: generating header files and makefiles
configure:28567: creating ./config.status
Running config.status.
This file was extended by netCDF config.status 3.6.2, which was
generated by GNU Autoconf 2.61. Invocation command line was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on ARL
config.status:1071: creating Makefile
config.status:1071: creating man/Makefile
config.status:1071: creating fortran/Makefile
config.status:1071: creating libsrc/Makefile
config.status:1071: creating nctest/Makefile
config.status:1071: creating nc_test/Makefile
config.status:1071: creating ncdump/Makefile
config.status:1071: creating ncgen/Makefile
config.status:1071: creating nf_test/Makefile
config.status:1071: creating cxx/Makefile
config.status:1071: creating f90/Makefile
config.status:1071: creating examples/Makefile
config.status:1071: creating examples/C/Makefile
config.status:1071: creating examples/CDL/Makefile
config.status:1071: creating examples/CXX/Makefile
config.status:1071: creating examples/F90/Makefile
config.status:1071: creating examples/F77/Makefile
config.status:1071: creating config.h
config.status:1318: config.h is unchanged
config.status:1071: creating fortran/nfconfig1.inc
config.status:1318: fortran/nfconfig1.inc is unchanged
config.status:1364: executing depfiles commands
config.status:1364: executing libtool commands
Cache variables.
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_bigendian=no
ac_cv_c_char_unsigned=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_c_ieeefloat=yes
ac_cv_cxx_compiler_gnu=no
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=set
ac_cv_env_CPPFLAGS_value=‘-DNDEBUG -DpgiFortran’
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=pgCC
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=
ac_cv_env_FC_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=no
ac_cv_fc_compiler_gnu=no
ac_cv_fc_srcext_f90=none
ac_cv_func_alloca_works=yes
ac_cv_func_strerror=yes
ac_cv_func_strlcat=no
ac_cv_header_dlfcn_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_member_struct_stat_st_blksize=yes
ac_cv_objext=o
ac_cv_path_EGREP=‘/bin/grep -E’
ac_cv_path_FGREP=‘/bin/grep -F’
ac_cv_path_GREP=/bin/grep
ac_cv_path_SED=/bin/sed
ac_cv_path_install=‘/usr/bin/install -c’
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP=‘cc -E’
ac_cv_prog_CXXCPP=‘pgCC -E’
ac_cv_prog_NM=‘/usr/bin/nm -B’
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=cc
ac_cv_prog_ac_ct_F77=pgf77
ac_cv_prog_ac_ct_FC=pgf95
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_cc_c_o=yes
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_f90_uppercase_mod=no
ac_cv_prog_fc_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_sizeof_double=8
ac_cv_sizeof_float=4
ac_cv_sizeof_int=4
ac_cv_sizeof_long=8
ac_cv_sizeof_off_t=8
ac_cv_sizeof_short=2
ac_cv_sizeof_size_t=8
ac_cv_sys_file_offset_bits=no
ac_cv_sys_largefile_CC=no
ac_cv_type_double=yes
ac_cv_type_float=yes
ac_cv_type_int=yes
ac_cv_type_long=yes
ac_cv_type_off_t=yes
ac_cv_type_ptrdiff_t=yes
ac_cv_type_short=yes
ac_cv_type_size_t=yes
ac_cv_type_ssize_t=yes
ac_cv_type_uchar=no
ac_cv_working_alloca_h=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=none
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd=‘$MAGIC_CMD’
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface=‘BSD nm’
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX=
lt_cv_path_NM=‘/usr/bin/nm -B’
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_c_o_FC=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=
lt_cv_sys_global_symbol_pipe=‘sed -n -e ‘'‘s/^.[ ]([ABCDGIRSTW][ABCDGIRSTW])[ ][ ]([_A-Za-z][_A-Za-z0-9])$/\1 \2 \2/p’'’’
lt_cv_sys_global_symbol_to_c_name_address=‘sed -n -e ‘'‘s/^: ([^ ]) $/ {"\1", (void ) 0},/p’'’ -e '''s/[1] ([^ ]) ([^ ])$/ {“\2”, (void ) &\2},/p’'‘’
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '''s/^T .
)$/extern int \1();/p’'’ -e ‘'‘s/[2]* .* (.*)$/extern char \1;/p’'’’
lt_cv_sys_max_cmd_len=32768
Output variables.
ACLOCAL=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run aclocal-1.9’
ALLOCA=‘’
AMDEPBACKSLASH=‘'
AMDEP_FALSE=’#’
AMDEP_TRUE=‘’
AMTAR=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run tar’
AR=‘ar’
AS=‘as’
AUTOCONF=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run autoconf’
AUTOHEADER=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run autoheader’
AUTOMAKE=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run automake-1.9’
AWK=‘gawk’
BUILD_CXX_FALSE=‘#’
BUILD_CXX_TRUE=‘’
BUILD_C_FALSE=‘#’
BUILD_C_TRUE=‘’
BUILD_DLL_FALSE=‘’
BUILD_DLL_TRUE=‘#’
BUILD_EXAMPLES_FALSE=‘#’
BUILD_EXAMPLES_TRUE=‘’
BUILD_F77_FALSE=‘#’
BUILD_F77_TRUE=‘’
BUILD_F90_FALSE=‘#’
BUILD_F90_TRUE=‘’
BUILD_SEPARATE_FORTRAN_FALSE=‘’
BUILD_SEPARATE_FORTRAN_TRUE=‘#’
BUILD_SHARED_FALSE=‘’
BUILD_SHARED_TRUE=‘#’
BUILD_UTILITIES_FALSE=‘#’
BUILD_UTILITIES_TRUE=‘’
BUILD_V2_FALSE=‘#’
BUILD_V2_TRUE=‘’
CC=‘cc’
CCDEPMODE=‘depmode=gcc3’
CFLAGS=‘-g -O2’
CPP=‘cc -E’
CPPFLAGS=‘-DNDEBUG -DpgiFortran’
CXX=‘pgCC’
CXXCPP=‘pgCC -E’
CXXDEPMODE=‘depmode=none’
CXXFLAGS=‘-g’
CYGPATH_W=‘echo’
DEFS=‘-DHAVE_CONFIG_H’
DEPDIR=‘.deps’
DLLTOOL=‘dlltool’
DUMPBIN=‘’
ECHO_C=‘’
ECHO_N=‘-n’
ECHO_T=‘’
EXEEXT=‘’
F77=‘pgf77’
FC=‘pgf95’
FCFLAGS=‘-g’
FCFLAGS_f90=‘’
FFLAGS=‘-g’
FTPBINDIR=‘/home/ftp/pub/binary/dummy_system’
GREP=‘/bin/grep’
INSTALL_DATA=‘${INSTALL} -m 644’
INSTALL_DOCS_FALSE=‘’
INSTALL_DOCS_TRUE=‘#’
INSTALL_PROGRAM=‘${INSTALL}’
INSTALL_SCRIPT=‘${INSTALL}’
INSTALL_STRIP_PROGRAM=‘${SHELL} $(install_sh) -c -s’
LARGE_FILE_TESTS_FALSE=‘’
LARGE_FILE_TESTS_TRUE=‘#’
LD=‘/usr/bin/ld -m elf_x86_64’
LDFLAGS=‘’
LIBOBJS=‘’
LIBS=‘’
LIBTOOL=‘$(SHELL) $(top_builddir)/libtool’
LN_S=‘ln -s’
LTLIBOBJS=‘’
MAKEINFO=‘${SHELL} /usr/local/netcdf-3.6.2/missing --run makeinfo’
MAKEWHATIS_CMD=‘’
MOD_FLAG=‘-I’
NETCDF_C_LIB=‘’
NM=‘/usr/bin/nm -B’
NMFLAGS=‘’
OBJDUMP=‘objdump’
OBJEXT=‘o’
PACKAGE=‘netcdf’
PACKAGE_BUGREPORT=‘> support@unidata.ucar.edu> ’
PACKAGE_NAME=‘netCDF’
PACKAGE_STRING=‘netCDF 3.6.2’
PACKAGE_TARNAME=‘netcdf’
PACKAGE_VERSION=‘3.6.2’
PATH_SEPARATOR=’:’
RANLIB=‘ranlib’
SED=‘/bin/sed’
SET_MAKE=‘’
SHAREEXT_DYLIB_FALSE=‘’
SHAREEXT_DYLIB_TRUE=‘#’
SHAREEXT_SL_FALSE=‘’
SHAREEXT_SL_TRUE=‘#’
SHELL=‘/bin/sh’
STRIP=‘strip’
TEST_F77_FALSE=‘#’
TEST_F77_TRUE=‘’
TEST_PARALLEL_FALSE=‘’
TEST_PARALLEL_TRUE=‘#’
UPPER_CASE_MOD_FALSE=‘’
UPPER_CASE_MOD_TRUE=‘#’
USE_FFIO_FALSE=‘’
USE_FFIO_TRUE=‘#’
USE_HDF5_DIR_FALSE=‘’
USE_HDF5_DIR_TRUE=‘#’
USE_NETCDF4_FALSE=‘’
USE_NETCDF4_TRUE=‘#’
USE_NETCDF_C_LIB_DIR_FALSE=‘’
USE_NETCDF_C_LIB_DIR_TRUE=‘#’
VERSION=‘3.6.2’
WHATIS=‘whatis’
ac_ct_CC=‘cc’
ac_ct_CXX=‘’
ac_ct_DUMPBIN=‘’
ac_ct_F77=‘pgf77’
ac_ct_FC=‘pgf95’
am__fastdepCC_FALSE=‘#’
am__fastdepCC_TRUE=‘’
am__fastdepCXX_FALSE=‘’
am__fastdepCXX_TRUE=‘#’
am__include=‘include’
am__leading_dot=‘.’
am__quote=‘’
am__tar=‘${AMTAR} chof - “$$tardir”’
am__untar=‘${AMTAR} xf -’
bindir=‘${exec_prefix}/bin’
build=‘x86_64-unknown-linux-gnu’
build_alias=‘’
build_cpu=‘x86_64’
build_os=‘linux-gnu’
build_vendor=‘unknown’
datadir=‘${datarootdir}’
datarootdir=‘${prefix}/share’
docdir=‘${datarootdir}/doc/${PACKAGE_TARNAME}’
dvidir=‘${docdir}’
exec_prefix=‘${prefix}’
host=‘x86_64-unknown-linux-gnu’
host_alias=‘’
host_cpu=‘x86_64’
host_os=‘linux-gnu’
host_vendor=‘unknown’
htmldir=‘${docdir}’
includedir=‘${prefix}/include’
infodir=‘${datarootdir}/info’
install_sh=‘/usr/local/netcdf-3.6.2/install-sh’
libdir=‘${exec_prefix}/lib’
libexecdir=‘${exec_prefix}/libexec’
localedir=‘${datarootdir}/locale’
localstatedir=‘${prefix}/var’
lt_ECHO=‘echo’
mandir=‘${datarootdir}/man’
mkdir_p=‘mkdir -p --’
oldincludedir=‘/usr/include’
pdfdir=‘${docdir}’
prefix=‘/usr/local/net*’
prog=‘’
program_transform_name=‘s,x,x,’
psdir=‘${docdir}’
sbindir=‘${exec_prefix}/sbin’
sharedstatedir=‘${prefix}/com’
sysconfdir=‘${prefix}/etc’
target_alias=‘’
confdefs.h.
define NF_INT2_T integer2
2
define SIZEOF_SHORT 2
define SIZEOF_INT 4
define SIZEOF_LONG 8
define SIZEOF_FLOAT 4
define SIZEOF_DOUBLE 8
define SIZEOF_OFF_T 8
define SIZEOF_SIZE_T 8
configure: exit 0
make
make all-recursive
make[1]: Entering directory /usr/local/netcdf-3.6.2' Making all in f90 make[2]: Entering directory /usr/local/netcdf-3.6.2/f90’
make[2]: all'nothing to do with make[2]: Leaving directory /usr/local/netcdf-3.6.2/f90’
Making all in fortran
make[2]: Entering directory /usr/local/netcdf-3.6.2/fortran' make all-am make[3]: Entering directory /usr/local/netcdf-3.6.2/fortran’
/bin/sh …/libtool --tag=CC --mode=link cc -g -O2 -o libnetcdff.la fort-attio.lo fort-control.lo fort-dim.lo fort-genatt.lo fort-geninq.lo fort-genvar.lo fort-lib.lo fort-misc.lo fort-v2compat.lo fort-vario.lo fort-var1io.lo fort-varaio.lo fort-varmio.lo fort-varsio.lo …/f90/libnetcdff90.la
libtool: link: rm -fr .libs/libnetcdff.a .libs/libnetcdff.la
libtool: link: (cd .libs/libnetcdff.lax/libnetcdff90.a && ar x /usr/local/netcdf-3.6.2/fortran/…/f90/.libs/libnetcdff90.a)
libtool: link: ar cru .libs/libnetcdff.a fort-attio.o fort-control.o fort-dim.o fort-genatt.o fort-geninq.o fort-genvar.o fort-lib.o fort-misc.o fort-v2compat.o fort-vario.o fort-var1io.o fort-varaio.o fort-varmio.o fort-varsio.o .libs/libnetcdff.lax/libnetcdff90.a/netcdf.o .libs/libnetcdff.lax/libnetcdff90.a/typeSizes.o
libtool: link: ranlib .libs/libnetcdff.a
libtool: link: rm -fr .libs/libnetcdff.lax
libtool: link: creating libnetcdff.la
libtool: link: ( cd “.libs” && rm -f “libnetcdff.la” && ln -s “…/libnetcdff.la” “libnetcdff.la” )
make[3]: Leaving directory /usr/local/netcdf-3.6.2/fortran' make[2]: Leaving directory /usr/local/netcdf-3.6.2/fortran’
Making all in libsrc
make[2]: Entering directory /usr/local/netcdf-3.6.2/libsrc' /bin/sh ../libtool --tag=CC --mode=link cc -g -O2 -o libnetcdf.la -rpath /usr/local/net*/lib -version-info 4:0:0 -no-undefined attr.lo ncx.lo putget.lo dim.lo error.lo libvers.lo nc.lo string.lo v1hpg.lo var.lo posixio.lo libnetcdf2.la ../fortran/libnetcdff.la libtool: link: rm -fr .libs/libnetcdf.a .libs/libnetcdf.la .libs/libnetcdf.lai libtool: link: (cd .libs/libnetcdf.lax/libnetcdf2.a && ar x /usr/local/netcdf-3.6.2/libsrc/./.libs/libnetcdf2.a) libtool: link: (cd .libs/libnetcdf.lax/libnetcdff.a && ar x /usr/local/netcdf-3.6.2/libsrc/../fortran/.libs/libnetcdff.a) libtool: link: ar cru .libs/libnetcdf.a attr.o ncx.o putget.o dim.o error.o libvers.o nc.o string.o v1hpg.o var.o posixio.o .libs/libnetcdf.lax/libnetcdf2.a/v2i.o .libs/libnetcdf.lax/libnetcdff.a/fort-varsio.o .libs/libnetcdf.lax/libnetcdff.a/fort-lib.o .libs/libnetcdf.lax/libnetcdff.a/fort-varaio.o .libs/libnetcdf.lax/libnetcdff.a/fort-var1io.o .libs/libnetcdf.lax/libnetcdff.a/fort-control.o .libs/libnetcdf.lax/libnetcdff.a/fort-genvar.o .libs/libnetcdf.lax/libnetcdff.a/fort-vario.o .libs/libnetcdf.lax/libnetcdff.a/fort-geninq.o .libs/libnetcdf.lax/libnetcdff.a/fort-attio.o .libs/libnetcdf.lax/libnetcdff.a/fort-v2compat.o .libs/libnetcdf.lax/libnetcdff.a/fort-misc.o .libs/libnetcdf.lax/libnetcdff.a/fort-genatt.o .libs/libnetcdf.lax/libnetcdff.a/fort-dim.o .libs/libnetcdf.lax/libnetcdff.a/netcdf.o .libs/libnetcdf.lax/libnetcdff.a/typeSizes.o .libs/libnetcdf.lax/libnetcdff.a/fort-varmio.o libtool: link: ranlib .libs/libnetcdf.a libtool: link: rm -fr .libs/libnetcdf.lax libtool: link: creating libnetcdf.la libtool: link: ( cd ".libs" && rm -f "libnetcdf.la" && ln -s "../libnetcdf.la" "libnetcdf.la" ) make[2]: Leaving directory /usr/local/netcdf-3.6.2/libsrc’
Making all in nctest
make[2]: Entering directory /usr/local/netcdf-3.6.2/nctest' make[2]: all’nothing to do with
make[2]: Leaving directory /usr/local/netcdf-3.6.2/nctest' Making all in ncgen make[2]: Entering directory /usr/local/netcdf-3.6.2/ncgen’
/bin/sh …/libtool --tag=CC --mode=link cc -g -O2 -o ncgen main.o load.o ncgentab.o escapes.o getfill.o init.o genlib.o …/libsrc/libnetcdf.la
libtool: link: cc -g -O2 -o ncgen main.o load.o ncgentab.o escapes.o getfill.o init.o genlib.o …/libsrc/.libs/libnetcdf.a
ncgentab.o: In function yy_get_next_buffer': ncgen.y:(.text+0xd74): undefined reference to __c_mcopy1’
ncgentab.o: In function yy_scan_bytes': ncgen.y:(.text+0x1519): undefined reference to __c_mcopy1’
ncgentab.o: In function `yyparse’
  1. ABCDGIRSTW ↩︎
  2. ABCDGIRSTW ↩︎
Hi Choingju,
I see two different issues. The first is that for some reason, using “env” before configure isn’t correctly setting the “CC”, “CFLAGS”, “FC”, etc environment variables. Try setting each individually in your shell (i.e. in csh “setenv CC pgcc”, or in bash “export CC=pgcc”) and then run configure and make.
The second error, the undefined references to “__c_mcopy1”, is most likely caused by mixing pgcc and gcc compiled objects. If this was your intent, then you’ll need to add the PGI C runtime library (-L/usr/pgi/linux86-64/7.1-6/lib -lpgc) to your link. Otherwise you need to build and link with either gcc or pgcc, not both. I’m guessing that fixing your configure will also fix this problem.
Hope this helps,
Mat
Dear Mat
  1. I added the lines(export CC=pgcc) in /etc/bashrc.
  2. but I didn’t understand about second problem. So please tell me in detail.
Choingjoo
Hi Choingjoo,
PGI compilers will often use highly optimized versions of common routines such as “memcopy”. These routines are located in the PGI C runtime library so you must link with libpgc in order for the linker to resolve these symbols. If you link with pgcc, then “-lpgc” is added by default. However, if you link with gcc (or ld), you need add “-L -lpgc” to the link line.
In this case, it appears to me that some of the objects were compiled with pgcc (perhaps left over from a previous build?) but you are linking with gcc. To fix, you need to either use pgcc to link or add “-L -lpgc” to the link line.
  • Mat
