I followed the instructions from https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=aarch64-jetson&Compilation=Native&Distribution=Ubuntu&target_version=20.04&target_type=deb_local to install CUDA 12.0 on my Jetson AGX Orin. It went fine. The next step was to install Python modules following instructions at CUDA Installation Guide for Linux. It failed. This step:
python3 -m pip install --upgrade setuptools pip wheel
Produces an error:
nick@orin:~$ python3 -m pip install --upgrade setuptools pip wheel
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com
/usr/share/python-wheels/urllib3-1.25.8-py2.py3-none-any.whl/urllib3/connectionpool.py:999: InsecureRequestWarning: Unverified HTTPS request is being made to host 'pypi.ngc.nvidia.com'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
Collecting setuptools
Downloading setuptools-65.6.3-py3-none-any.whl (1.2 MB)
|████████████████████████████████| 1.2 MB 1.0 MB/s
Collecting pip
Downloading pip-22.3.1-py3-none-any.whl (2.1 MB)
|████████████████████████████████| 2.1 MB 4.4 MB/s
Collecting wheel
Downloading wheel-0.38.4-py3-none-any.whl (36 kB)
ERROR: launchpadlib 1.10.13 requires testresources, which is not installed.
Installing collected packages: setuptools, pip, wheel
WARNING: The scripts pip, pip3, pip3.10 and pip3.8 are installed in '/home/nick/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
WARNING: The script wheel is installed in '/home/nick/.local/bin' which is not on PATH.
Successfully installed pip-22.3.1 setuptools-65.6.3 wheel-0.38.4
I installed missing testresources
. The next steps failed completely:
nick@orin:~$ python3 -m pip install nvidia-pyindex
Defaulting to user installation because normal site-packages is not writeable
Collecting nvidia-pyindex
Downloading nvidia-pyindex-1.0.9.tar.gz (10 kB)
Preparing metadata (setup.py) ... done
Building wheels for collected packages: nvidia-pyindex
Building wheel for nvidia-pyindex (setup.py) ... done
Created wheel for nvidia-pyindex: filename=nvidia_pyindex-1.0.9-py3-none-any.whl size=8418 sha256=7a4b9795dfe2295a78e2f056de7f86e2b9f78de79e23ac5fcd178da9623a7647
Stored in directory: /tmp/pip-ephem-wheel-cache-jnlv9z1v/wheels/11/a2/1a/2caaf9725a10ed91ab89274afabbfa70ab3db002f93600feae
Successfully built nvidia-pyindex
Installing collected packages: nvidia-pyindex
WARNING: The script nvidia_pyindex is installed in '/home/nick/.local/bin' which is not on PATH.
Successfully installed nvidia-pyindex-1.0.9
nick@orin:~$ python3 -m pip install nvidia-cuda-runtime-cu12
Collecting nvidia-cuda-runtime-cu12
Downloading nvidia-cuda-runtime-cu12-0.0.1.dev5.tar.gz (4.3 kB)
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [17 lines of output]
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/tmp/pip-install-rdffxd6q/nvidia-cuda-runtime-cu12_cad2da2971e04a3ab98caed1f9a96920/setup.py", line 152, in <module>
raise RuntimeError(open("ERROR.txt", "r").read())
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
This package can be installed as:
$ pip install nvidia-pyindex
$ pip install nvidia-cuda-runtime-cu12
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Is there a solution to this problem? Preferably using Pip.
