Hi there!
I am trying to install PyTorch v2.1.0 and Torchvision v0.16.1 on my Jetson Orin Nano Developer Kit running on JetPack 5.1.2, following the instrcutions from PyTorch for Jetson
I experience the following behavior that I do not really understand:
Why does the command install torch-1.8.0 and not torch-2.1.0 as the wheel name would suggest?
Later in the process I experience the following error:
~/torchvision$ python3 setup.py install --user
File "setup.py", line 9, in <module>
import torch
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 195, in <module>
_load_global_deps()
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 148, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.8/ctypes/__init__.py", line 373, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libmpi_cxx.so.20: cannot open shared object file: No such file or directory
Maybe this second error is due to the fact that torch-1.8.0 and not 2.1.0 is installed?
I checked the following:
Thanks for your answer @dusty_nv! Indeed I got the URL wrong.
However, I still face problems when I want to install Torchvision:
$ sudo apt-get install libjpeg-dev zlib1g-dev libpython3-dev libopenblas-dev libavcodec-dev libavformat-dev libswscale-dev
$ git clone --branch v0.16.1 https://github.com/pytorch/vision torchvision # see below for version of torchvision to download
$ cd torchvision
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 174, in _load_global_deps
OSError: libcufft.so.11: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
import torch
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 234, in <module>
_load_global_deps()
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 195, in _load_global_deps
_preload_cuda_deps(lib_folder, lib_name)
File "/home/user/.local/lib/python3.8/site-packages/torch/__init__.py", line 160, in _preload_cuda_deps
raise ValueError(f"{lib_name} not found in the system path {sys.path}")
ValueError: libcublas.so.*[0-9] not found in the system path ['/home/user/torchvision', '/usr/lib/python38.zip', '/usr/lib/python3.8', '/usr/lib/python3.8/lib-dynload', '/home/user/.local/lib/python3.8/site-packages', '/usr/local/lib/python3.8/dist-packages', '/usr/lib/python3/dist-packages', '/usr/lib/python3.8/dist-packages']
Now, the error does not involve libmpi_cxx.so.20 anymore but libcufft.so.11 and libcublas.so.*[0-9].
Do you have an idea how to fix this? Thanks!
