Description
Hi, I’m trying to build my centerNet model with INT8 engine.
I have built INT8 engine, but the calibration cache was not created.
I have ran it several times using tensorrt.Builder.build_engine() or tensorrt.Builder.build_cuda_engine(), but calibration cache was still not created.
I think write_calibration_cache() method wasn’t called, but I have no idea why this happen.
The API seems to be a little different between the version I use and the latest version of sensorrt. Are there some example for tensorrt 7.2.x?
I’d appreciate a lot if someone could give me advice.
And I have another question: int8 mode and calibrator can be set in tensort.Builder. Also, int8 mode and calibrator can be set in tensorrt.IBbuilderConfig. The difference between that two option seems to be tensorrt.Builder.build_engine() and tensorrt.Builder.build_cuda_engine(). What is the difference between the two ways to build an engine?
Environment
TensorRT Version: 7.2.2.1
GPU Type: Nvidia Titan Xp
Nvidia Driver Version:
CUDA Version: 11.1
CUDNN Version: 8.0.5
Operating System + Version: CentOS 7.9.2009
Python Version (if applicable): 3.8.5
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.9.0
Baremetal or Container (if container which image + tag): container (nvcr.io/nvidia/tensorrt:20.12-py3)
