INT8 convolution using cuDNN Python Frontend
We are working on bringing a simple INT8 conv2d operator into PyTorch using the python cuDNN Frontend (version 1.14, backend 90501).
However, when adapting the sample FP16 convolution notebook (00_introduction.ipynb) to INT8, we get wrong results compared to PyTorch’s conv2d:
pytorch: tensor([[[[ 10581, -49822,   9887],
          [ -5654,  11015, -20480],
          [ -5404,   9559,  -1994]]]], device='cuda:0', dtype=torch.int32)
cudnn: tensor([[[[-2139127681,  2139127935,         128],
          [          0,           0,           0],
          [          0,           0,           0]]]], device='cuda:0',
       dtype=torch.int32)
Here is the converted sample code we used :
import cudnn
import torch
print(cudnn.backend_version())
handle = cudnn.create_handle()
graph = cudnn.pygraph(
    handle=handle,
    name="cudnn_graph_0",
    io_data_type=cudnn.data_type.INT8,
    compute_data_type=cudnn.data_type.INT32,
X = graph.tensor(
    name="X",
    dim=[1, 1, 5, 5],
    stride=[5 * 5 * 1, 1, 5 * 1, 1],
W = graph.tensor(name="W", dim=[1, 1, 3, 3], stride=[3 * 3 * 1, 1, 3 * 1, 1])
Y = graph.conv_fprop(
    X,
    W,
    padding=[0, 0],
    stride=[1, 1],
    dilation=[1, 1],
Y.set_output(True)
graph.build([cudnn.heur_mode.A])
X_gpu = torch.randint(-128, 127, (
    1, 1, 5, 5), requires_grad=False, device="cuda", dtype=torch.int8
).to(memory_format=torch.channels_last)
W_gpu = torch.randint(-128, 127, (
    1, 1, 3, 3), requires_grad=False, device="cuda", dtype=torch.int8
Y_gpu = torch.zeros(
    1, 1, 3, 3, requires_grad=False, device="cuda", dtype=torch.int32
workspace = torch.empty(graph.get_workspace_size(), device="cuda", dtype=torch.int32)
graph.execute({X: X_gpu, W: W_gpu, Y: Y_gpu}, workspace, handle=handle)
truth = torch.nn.functional.conv2d(X_gpu.to(torch.float32), W_gpu.to(torch.float32)).to(torch.int32)
print("pytorch:", truth)
print("cudnn:", Y_gpu)
This is surprising as PyTorch is also using the NCHW representation and the stride computation lookd correct. The values are correctly aligned on 16 bits.
The GPU used is a RTX 4080, if that’s relevant.
Are we missing a step in or is there a known limitation for INT8 foward prop ?
Thanks a lot for the help.
The strides specified for X and W do not match NCHW layout.
If the tensors use the NCHW layout, the strides for X should be [25, 25, 5, 1], and the strides for W should be [9, 9, 3, 1].
