Int8 performance is less than fp16
Description: int8 performance is less than fp16
NVIDIA Release: 22.05
NVIDIA TensorRT Version: 8.2.5
NVIDIA Driver Version: 515.47.03
CUDA Version: 11.7
NVIDIA GPU: NVIDIA A100-PCIE-40GB
Docker Image: nvcr.io/nvidia/tensorrt:22.05-py3
Model location: bert_pyt_onnx_large_qa_squad11_amp | NVIDIA NGC
(Download command: wget ‘https://api.ngc.nvidia.com/v2/models/nvidia/bert_pyt_onnx_large_qa_squad11_amp/versions/1/files/bert_large_v1_1.onnx’)
Command: trtexec --useCudaGraph --loadEngine=<ENGINE_NAME>.trt --shapes=segment_ids:1x384,input_mask:1x384,input_ids:1x384 --duration=300 --verbose <PRECISION_FLAG>
Model Name Seq length Precision Batch Size Throughput E2E Latency(ms) GPU Latency(ms)
bert_large_v1_1 384 INT8 1 178.08 11.0478 5.6124
bert_large_v1_1 384 FP16 1 340.16 5.7558 2.9348
bert_large_v1_1 384 best 1 339.91 5.7650 2.9370
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
I checked the model using check_model.py. I don’t see any error in ONNX model.
Following are the commands I used to get inference data:
  1. For INT8 precision:
    trtexec --useCudaGraph --loadEngine=bert_large_v1_1-int8.trt --int8 --shapes=segment_ids:1x384,input_mask:1x384,input_ids:1x384 --duration=300 --verbose
  2. For FP16 precision:
    trtexec --useCudaGraph --loadEngine=bert_large_v1_1-fp16.trt --fp16 --shapes=segment_ids:1x384,input_mask:1x384,input_ids:1x384 --duration=300 --verbose
  3. For BEST precision:
    trtexec --useCudaGraph --loadEngine=bert_large_v1_1-best.trt --best --shapes=segment_ids:1x384,input_mask:1x384,input_ids:1x384 --duration=300 --verbose
We do not support INT8-PTQ for the ONNX-BERT path yet.
To use ONNX-BERT with INT8, please use the QAT path (by explicitly inserting Q/DQ nodes).
Please refer,
Thank you.
