Integrate Perceptor with Object Detection
I am trying to display the object detection on the 3D reconstruction output by the Perceptor shown below. However, when I run the perceptor and the yolov8 object detection in the same time using the command ros2 launch nova_developer_kit_bringup perceptor.launch.py stereo_camera_configuration:=front_configuration use_foxglove_whitelist:=False and ros2 launch isaac_ros_examples isaac_ros_examples.launch.py launch_fragments:=argus_mono,rectify_mono,yolov8 model_file_path:={ISAAC_ROS_WS}/isaac_ros_assets/models/yolov8/yolov8s.onnx engine_file_path:={ISAAC_ROS_WS}/isaac_ros_assets/models/yolov8/yolov8s.plan, the following error shows:
[component_container_mt-3] 2024-07-16 11:07:48.503 ERROR extensions/hawk/components/argus_camera.cpp@442: Failed to get CaptureSession interface
[component_container_mt-3] 2024-07-16 11:07:48.503 ERROR extensions/hawk/components/argus_camera.cpp@1074: Error while setting up output streams
[component_container_mt-3] 2024-07-16 11:07:48.503 WARN  gxf/std/entity_executor.cpp@495: Failed to start entity [DSOYNWGPGL_argus_camera]
[component_container_mt-3] 2024-07-16 11:07:48.503 WARN  gxf/std/event_based_scheduler.cpp@329: Error while executing entity E74 named 'DSOYNWGPGL_argus_camera': GXF_FAILURE
[component_container_mt-3] 2024-07-16 11:07:48.503 ERROR gxf/std/entity_executor.cpp@586: Entity [DSOYNWGPGL_argus_camera] must be in Started, Tick Pending, Ticking or Idle stage before stopping. Current state is StartPending
Is there anyway to achieve the object detection with 3D reconstruction shown in the perceptor tutorial? Thank you!!!
Best,
Jacky
Hi JackyC,
Thank you for your post.
About the camera error, I suspect that you might have run anothor perceprtor demo prior to running these two commands. If so, please ensure that you run only one perceprtor demo.
As there haven’t been any recent updates on this discussion, we’ll be closing the thread to keep the forum organized.
If you continue to experience this issue or have new questions, please start a new topic and include a reference to this discussion for context. This will help our team and other community members assist you more effectively.
Thank you for your participation in the NVIDIA Isaac ROS community.
