Integrating Custom trained yolov4 in Deepstream 5.1
• Hardware: Triton Inference Server
• Network Type : YOLOv4
Hi , I have custom trained yolov4 on tao toolkit version 3.22.05. The model was trained successfully . Now i am interested in integrating it with existing deepstream 5.1 sdk which in already in production.
Can you guide as to how to go ahead with this integration as i have tried the following but it failed
  1. Exported the model , however could not find compatible config file for integrating it with deepstream 5.1. tried by changing parameters of yolov3 config. However it gives an error
  2. Downgrading the nvidia-tao to make the model compatible with deepstream5.1 and tried exporting however export code does not work
    (Do i need to retrain the model with downgraded version of tao so that it is compatible with deepstream 5.1)
Kindly suggest
Please try to check if it works after git clone "-b release/tao3.0 " branch.
$ git clone -b release/tao3.0 GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream · GitHub
For the config file, refer to
deepstream_tao_apps/configs/yolov4_tao/pgie_yolov4_tao_config.txt at release/tao3.0 · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
Please share the log.
