Hello all,
I am getting crazy with a compilation problem, that I am sure it has to be something easy. Hopefully someone of you can help me.
First I have checked this post (The Official NVIDIA Forums | NVIDIA) where a CUDA integration with C++ is very well explained. I did exactly the same but obtaining a static library “.a”
This Makefile looks like below, and it works fine creating the library source .a
[codebox]CUDA_INSTALL_PATH ?= /usr/local/cuda
ROOTDIR ?= /home/chema/NVIDIA_GPU_Computing_SDK/C/src
LIBDIR := $(ROOTDIR)/…/lib
COMMONDIR := $(ROOTDIR)/…/common
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc
LIB := -L$(CUDA_INSTALL_PATH)/lib -L$(LIBDIR) -L$(COMMONDIR)/lib/linux -lcuda
all: build/source.a
build/source.a: build/source.o build/simpleGPU_launcher.o
ar rcs build/source.a build/*.o
build/source.o: src/source.cpp include/libaco/source.h
g++ -Wall -ansi -I ./include -c src/source.cpp -o build/source.o -O3
build/simpleGPU_launcher.o: src/simpleGPU_launcher.cu
/usr/local/cuda/bin/nvcc --compiler-options -fno-strict-aliasing \
$(INCLUDES) \
$(LIB)\
-DUNIX -O2 -o build/simpleGPU_launcher.o -c src/simpleGPU_launcher.cu
[/codebox]
After that, in other directory I want to use that library and also compile other files
The makefile looks like this (I have tried to summarized a little bit)
[codebox]bin/source2: source build/source2.o
cp ../../source/trunk/build/source.a lib/
g++ -static build/source2.o -L./lib/ -lsource -o bin/source2
build/source2.o: src/source.cpp
g++ -Wall -ansi -I include/ -c src/source2.cpp -o build/source2.o
source:
make -C ../../source/trunk -f ../../source/trunk/Makefile
[/codebox]
When I use this make file, I have obtained messages like this
tmpxft_00003635_00000000-10_simpleGPU_launcher.ii:(.text+0x69b): undefined reference to `cudaSetDevice’
tmpxft_00003635_00000000-10_simpleGPU_launcher.ii:(.text+0x6b8): undefined reference to `cudaMalloc’
tmpxft_00003635_00000000-10_simpleGPU_launcher.ii:(.text+0x6da): undefined reference to `cudaMemcpy’
I assume that is because it can not link with CUDA lirbaries. However, I tried to use the -L option in the first and second Makefile to indicate the path of the cuda libraries, but it is not working.
Any idea?
Many thanks in advance
Cheers
