Okay a little more information about my errors. This is what is getting thrown up:
PGF90-S-0000-Internal compiler error. unsupported procedure 491 (cart_force.f: 593)
device_dener:
360, Memory zero idiom, array assignment replaced by call to pgf90_mzero8
361, Memory zero idiom, array assignment replaced by call to pgf90_mzero8
0 inform, 0 warnings, 2 severes, 0 fatal for device_dener
PGF90-S-0000-Internal compiler error. unsupported procedure 412 (cart_force.f: 861)
device_overlp:
675, Memory zero idiom, array assignment replaced by call to pgf90_mzero8
0 inform, 0 warnings, 1 severes, 0 fatal for device_overlp
device_ssmndo:
973, Invariant assignments hoisted out of loop
974, Invariant assignments hoisted out of loop
975, Invariant assignments hoisted out of loop
976, Invariant assignments hoisted out of loop
/tmp/pgcudafor-N5g9oojuX6k.gpu(2704): error: expected an identifier
/tmp/pgcudafor-N5g9oojuX6k.gpu(2988): error: expected a “(”
/tmp/pgcudafor-N5g9oojuX6k.gpu(2990): error: expected an expression
/tmp/pgcudafor-N5g9oojuX6k.gpu(2994): error: expected a “(”
/tmp/pgcudafor-N5g9oojuX6k.gpu(2996): error: expected an expression
/tmp/pgcudafor-N5g9oojuX6k.gpu(3000): error: expected a “(”
/tmp/pgcudafor-N5g9oojuX6k.gpu(3002): error: expected an expression
/tmp/pgcudafor-N5g9oojuX6k.gpu(3012): error: expected a “(”
/tmp/pgcudafor-N5g9oojuX6k.gpu(3014): error: expected an expression
9 errors detected in the compilation of “/tmp/pgnvdZO5gzjCaJeSx.nv0”.
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code 0 (cart_force.f: 5226)
PGF90/x86-64 Linux 10.8-0: compilation aborted
make[1]: *** [cart_force.o] Error 2
I’d really appreciate it if anyone could shed a little light on this situation.
Cheers,
Crip_crop
