Is there a pull-up resistor on VIN_PWR_BAD_N pin in Xavier module? On the carrier board, all the MOSFETs connected to the pin are open-drain, so there should be one in the module. Can anyone confirm that?
Related topics
Topic | Replies | Views | Activity | |
Pull Up on Force Recovery | 2 | 514 | November 29, 2022 | |
Is there any internal Pull up resistor in SOC pin F9 (GPIO16)? | 2 | 332 | May 22, 2023 | |
OEM design guide question on Figure 21 USB 3.1 Micro AB | 1 | 324 | September 30, 2019 | |
UART internal pull up | 6 | 854 | October 18, 2021 | |
Xavier Industrial SOM drawing | 4 | 542 | August 17, 2022 | |
Jetson Xavier System Pins | 4 | 1035 | October 18, 2021 | |
Internal Pullup/Pulldown value for Xavier AGX Module and Xavier NX | 5 | 1107 | March 9, 2022 | |
how to understand VIN_PWR_BAD_N signal on the carrier board of xavier | 2 | 705 | October 18, 2021 | |
jetson tx2 VIN_PWR_BAD control circuit do not understand | 2 | 769 | May 8, 2018 | |
AGX MODULE_POWER_ON voltage rating | 2 | 377 | October 18, 2021 |
