Introducing Spark Auto Round /w OpenCode Instruct dataset
An Int4 AutoRound quantization tool focused on the DGX Spark GB10 architecture
github.com/whpthomas/spark-auto-round
TLDR
Quantization seems to smooth out ‘knowledge’ and ‘emergent behaviour’ noise from the model. Using a dataset that closely matches your use case effectively ‘trains’ the model by filtering out unwanted noise, improving test scores.
Background
I have to choose a model to setup on client GB10 systems. This production model needs to be multi-modal. I also need some memory left over to run my main application.
Like many here I seem to be downloading new quantized models to my DGX Spark every week. The cycle is always the same: I swear this is my new daily driver, then there is an annoncement, a throng of forum activity and I grab the model from HuggingFace, serve it with vllm, and cross my fingers – this model be the one to rule them all!
There are some great models now, they work well for me, but are they the best choice for my clients? They code well or they don’t, but I never really understood why the good ones were better or how well they really worked.
To be honest I really had no idea which quantization was optimal for my clients particular use case.
So I started digging.
The Adaptive Sensitivity-Aware Quantization hypothesis
What if quantising sensitive layers were dragging down quality? I had seen a concept like this being discussed so I decided to experiment with it. The first thing was to generate quantization reports that detect problematic layers.
I tried implemeting Router KL Divergence, Hessian Trace Approximation, Layer-wise Peak Signal-to-Noise Ratio, Kurtosis & Outlier Detection, Fisher Information Trace but most of these tests either blew up memory or analysis time. So I settled on the cheap and cheerful combination of cosine similarity (perplexity) below 0.99 and Peak Signal-to-Noise Ratio (PSNR) under 45 dB, and sticking with dense models for now.
My hypothesis was that replacing sensitive layers with FP16 would improve model quality. I built spark-asqa-substitute — a utility that takes a working quantized model, identifies the sensitive layers, then swaps them out with FP16 from teh origianl model. The resulting output loaded and ran fine in vllm. A mixed INT4 + FP16 layer model is the best of both worlds – right?
The benchmark told a different story.
Int4 AutoRound: 92/100
Int4 AutoRound + ASAQ (layers 54, 58): 87/100
Five points lower. Not higher. Why?
My best guess — those layers are sensitive. But the Signed Gradient Decent algorithm had already found optimal rounding for them. Breaking that optimization by substituting FP16 degraded the model’s tool-calling ability. Maybe the vectors live in a different number space or magnitude? Maybe the quantizer knows what it’s doing? I don’t know, I didn’t see any improvement and down in this rabbit hole the light from the opening above me was getting dim.
This marked a turning point. Observing quality measures wasn’t just nice to have — it was the entire point.
Observability changes everything
When I could see per-layer sensitivity during quantization, the optimization process transformed from guesswork into engineering.
🟢 model.layers.0      Cosine 0.9965  PSNR 51.1 dB    PASS
🟢 model.layers.1      Cosine 0.9967  PSNR 52.2 dB    PASS
🟠 model.layers.22     Cosine 0.9912  PSNR 44.7 dB    WARN
🟠 model.layers.23     Cosine 0.9883  PSNR 46.5 dB    WARN
The quantization-report.txt tells you which layers to track. It doesn’t just say “this model is quantized” — it says how well each layer survived the process.
So in parallel to ASAQ I also started iterating calibration datasets using the Qwen 3.5 0.8B model – which only takes 1:30 hours for each run, so at least I could get through a few iterations each day. My second hypothesis was that improvments on this smaller model would translate across to the larger 27B target.
First I tweaked all the auto-round settings, then I explored different datasets. The default dataset was pile-10k (Intel’s recommendation). So I tried github-code-clean, which was better, but optimal? So I tried ultrachat_200k. Each time, I’d quantize, benchmark, compare and track the layer error rates.
Then I added support for NVIDIA’s OpenCode Instruct dataset.
This dataset changed the score
OpenCode Instruct is a 5M-sample dataset of coding instructions and solutions. The schema is rich: input, output, unit_tests, llm_judgement, average_test_score. For calibration, I concatenated input and output. This is a diverse code context that I was hoping would ‘teach’ the quantizer what matters for long context agentic toolcall workflows, not chat.
The results were significant.
Qwen 3.5 0.8B — Tool Eval Bench scores by dataset:
Dataset Score Pass/Fail
OpenCode Instruct 69 41/13/15
github-code-clean 67 39/14/16
pile-10k 62 37/11/21
OpenCode Instruct outperformed all other models including the baseline fp16 test core of 67. But would this generalize?
Qwen 3.6 27B with OpenCode Instruct: 92/100.
The model passed 59 scenarios, got partial credit on 9, and failed 1 (a sleeper injection test that caught a real security issue) using MTP=3 speculative decoding (dflash=6 scores worse).
  • Quantization command: spark-auto-round --dataset "opencode-instruct" Qwen/Qwen3.6-27B
  • MTP averages ~26.4 t/s with num_speculative_tokens: 3 for longer context and agentic coding
  • DFlash averages ~38.1 t/s with num_speculative_tokens: 6 for shorter context and instruction following
# Model Scheme Dataset Score t/s Rating P/F Tokens
🥇 qwen3.6-27b-sar-oc-mpt Int4 OpenCode Instruct 92 26.4 ★★★★★ 59/9/1 284K
🥈 qwen3.6-27b-sar-oc-dflash Int4 OpenCode Instruct 90 38.1 ★★★★★ 57/10/2 265K
🥉 qwen/qwen3.6-27b-fp8 fp8 - 88 18.1 ★★★★ 57/8/4 275K
4 qwen3.6-27b-sar-oc Int4 OpenCode Instruct 88 12.5 ★★★★ 57/8/4 275K
5 qwen3.6-27b-sar-git-mtp Int4 Github Code Clean 86 26.2 ★★★★ 54/10/5 268K
6 qwen/qwen3.6-27b bf16 - 83 11.4 ★★★★ 53/9/7 243K
I am optimistic.
What spark-auto-round actually does
It’s a trimmed-down fork of Intel’s auto-round. I removed everything that isn’t needed by auto-round on CUDA with torch.compile:
  • No GGUF, no MLX, no Gaudi HPU support
  • No diffusion model evaluation
  • No CPU fallback
  • No 8-bit or 2-bit quantization
What’s left is a simple command line:
spark-auto-round Qwen/Qwen3.6-27B
One command. W4A16 quantization, optimal GB10 settings with torch.compile always enabled. The output goes to ./models/Qwen3.6-27B-int4-AutoRound/.
A quantization-report.txt appears alongside the model weights.
The defaults are tuned for GB10 are:
Setting Default Why
--iters 1000 Enough for convergence, not so many it wastes time
--nsamples 512 Good coverage without memory pressure
--seqlen 2048 Balances context depth with calibration speed
--batch_size 8 Fits comfortably in 128GB unified memory
--group_size 128 Standard for INT4 quantization
--dataset github-code-clean Solid baseline, but use opencode-instruct for best results
For large models that exceed memory:
spark-auto-round Qwen/Qwen3.5-122B-A10B --memory_utilization 75
The tool auto-detects whether the model fits in memory. If it doesn’t, it offloads blocks to disk and quantizes them one at a time. You control the threshold with --memory_utilization (50-95%).
Why not NVFP4?
While NVFP4 suppport has improved significantly, I wanted a reference INT4 implementation for comparison. AutoRound is the most mature INT4 quantization method with vllm. By optimizing it specifically for GB10, I get a more reliable baseline for a true apples to apples comparison.
What’s next
The quantization reports revealed that the last few layers in every model are consistently sensitive. I suspect this is a general property of transformer architectures — the output layers are inherently more sensitive to weight perturbation because they’re closer to the loss surface.
I’d like to explore whether this insight can inform better default settings. For proecessing really /newlarge models, maybe fewer iterations on early layers, more on late layers? Maybe different group sizes per layer? The observability makes these questions answerable.
Try it
python -m venv .sar-venv
source .sar-venv/bin/activate
pip install git+https://github.com/whpthomas/spark-auto-round.git
spark-auto-round Qwen/Qwen3.6-27B --dataset opencode-instruct
The quantized model serves with vllm. The README has a complete docker command.
If you’re interested in experimenting with quantized models on your Spark, I’d love to hear your results. Open an issue, share your quantization-report.txt, tell me what’s working and what isn’t. The whole point of this tool is to make quantization results more observable. So we can understand and reason about them.
This looks interesting to try.
Have you attempted this on the Qwen3.6-35B-A3B model?
I keep running into a crash whenever I run it.
(.venv) dcolt@gx10-c046:~/spark-auto-round$ spark-auto-round Qwen/Qwen3.6-35B-A3B
2026-06-16 17:40:35 INFO main.py L143: Spark Auto Round version 0.14.1
–batch_size 8
–nsamples 512
–seqlen 2048
–group_size 128
–iters 1000
–dataset github-code-clean
–output_dir ./models
2026-06-16 17:40:35 INFO main.py L169: torch.compile is enabled to reduce tuning costs. Disable with --disable_torch_compile if it causes issues.
2026-06-16 17:40:35 INFO main.py L177: start to quantize Qwen/Qwen3.6-35B-A3B
2026-06-16 17:40:35 WARNING memory.py L245: Cannot estimate parameter count from config — hidden_size or intermediate_size missing. Defaulting to 0 (will use whole-model path).
2026-06-16 17:40:36 INFO memory.py L329: Memory analysis:
Model: Qwen/Qwen3.6-35B-A3B
Parameters: 0.0B
Model size: 0.0 GB (bfloat16)
Available: 66.6 GB
Threshold: 50.0 GB (75%)
Strategy: whole-model (fits in memory)
Blocks: 40 layers
Block size: ~0 MB each
Warning: You are sending unauthenticated requests to the HF Hub. Please set a HF_TOKEN to enable higher rate limits and faster downloads.
Fetching 26 files: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 26/26 [00:00<00:00, 4809.98it/s]
Download complete: : 0.00B [00:00, ?B/s] [transformers] The fast path is not available because one of the required library is not installed. Falling back to torch implementation. To install follow GitHub - fla-org/flash-linear-attention: 🚀 Efficient implementations for emerging model architectures · GitHub and GitHub - Dao-AILab/causal-conv1d: Causal depthwise conv1d in CUDA, with a PyTorch interface · GitHub | 0/26 [00:00<?, ?it/s]
Loading weights: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 693/693 [00:00<00:00, 9326.69it/s]
2026-06-16 17:40:39 WARNING logging.py L340: some layers are skipped quantization (shape not divisible by 32): model.layers.[0-39].mlp.shared_expert_gate
2026-06-16 17:40:39 INFO replace_modules.py L120: Experts (before replacement) [model.layers.0.mlp.experts] (Qwen3_5MoeExperts):
Qwen3_5MoeExperts(
(act_fn): SiLUActivation()
2026-06-16 17:40:39 INFO memory.py L487: [Memory Monitor] Before applying custom replacements: ‘peak_ram’: 1.02GB
2026-06-16 17:40:39 INFO replace_modules.py L360: Found 40 modules to replace
Replacing modules: 0%| | 0/40 [00:00<?, ?it/s]
File “/home/dcolt/spark-auto-round/.venv/bin/spark-auto-round”, line 8, in
sys.exit(run())
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/main.py”, line 268, in run
start()
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/main.py”, line 133, in start
tune(args)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/main.py”, line 261, in tune
model, folders = autoround.quantize_and_save(args.output_dir, format=format)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/compressors/base.py”, line 1248, in quantize_and_save
self.post_init()
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/compressors/data_driven.py”, line 122, in post_init
super().post_init()
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/compressors/base.py”, line 538, in post_init
self._patch_model()
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/compressors/base.py”, line 746, in _patch_model
self.model_context.apply_patches(self.formats)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/context/model.py”, line 239, in apply_patches
self.model = update_module(
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/special_model_handler.py”, line 394, in update_module
model = apply_replacements(model)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/modeling/fused_moe/replace_modules.py”, line 318, in apply_replacements
_apply_custom_replacements(model)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/utils/device/memory.py”, line 488, in wrapper
result = func(*args, **kwargs)
File “/home/dcolt/spark-auto-round/.venv/lib/python3.12/site-packages/auto_round/modeling/fused_moe/replace_modules.py”, line 370, in _apply_custom_replacements
with dump_memory_usage_ctx(f"Replacing module {name}", log_level=“debug”):
TypeError: ‘generator’ object does not support the context manager protocol
Running it on the Qwen3.6-27B seems to be working just fine.
@whpthomas Have you thought about uploading your optimised quants to HF?
Could build up a full collection with a leaderboard helping users to pick the right fit for them.
I have but I live in a rural area in Australia, and the models are just to large to upload sucessfully.
Thanks, I pushed a fix. I was planning to Quantize 35b next – there was an attribute pattern match missing.
I would recommend spark-auto-round --dataset "opencode-instruct" Qwen/Qwen3.6-35B-A3B
2026-06-17 05:36:36 INFO __main__.py L143: Spark Auto Round version 0.14.1
  --batch_size 8
  --nsamples 512
  --seqlen 2048
  --group_size 128
  --iters 1000
  --output_dir ./models
2026-06-17 05:36:36 INFO __main__.py L169: `torch.compile` is enabled to reduce tuning costs. Disable with --disable_torch_compile if it causes issues.
2026-06-17 05:36:36 INFO __main__.py L177: start to quantize Qwen/Qwen3.6-35B-A3B
2026-06-17 05:36:37 INFO memory.py L336: Memory analysis:
  Parameters:     33.4B
  Model size:     62.2 GB (bfloat16)
  Available:      44.3 GB
  Threshold:      33.3 GB (75%)
  Strategy:       block-offload (model exceeds threshold)
  Blocks:         40 layers
  Block size:     ~1592 MB each
Fetching 26 files: 100%|████████████████████████████████████████████████████████████████████████████████████████████| 26/26 [00:00<00:00, 3202.79it/s]
Download complete: : 0.00B [00:00, ?B/s]              [transformers] The fast path is not available because one of the required library is not installed. Falling back to torch implementation. To install follow https://github.com/fla-org/flash-linear-attention#installation and https://github.com/Dao-AILab/causal-conv1d
Loading weights: 100%|████████████████████████████████████████████████████████████████████████████████████████████| 693/693 [00:00<00:00, 9844.88it/s]
2026-06-17 05:36:41 WARNING logging.py L340: Skipped quantization for 40 layer(s) with shape not divisible by 32: model.layers.[0-39].mlp.shared_expert_gate. These layers will run in full precision (bf16) — this is expected for small/gate layers and has negligible impact.
2026-06-17 05:36:41 INFO replace_modules.py L120: Experts (before replacement) [model.layers.0.mlp.experts] (Qwen3_5MoeExperts):
Qwen3_5MoeExperts(
2026-06-17 05:36:41 INFO memory.py L495: [Memory Monitor] Before applying custom replacements: 'peak_ram': 0.99GB
2026-06-17 05:36:41 INFO replace_modules.py L360: Found 40 modules to replace
Replacing modules: 100%|██████████████████████████████████████████████████████████████████████████████████████████████| 40/40 [00:01<00:00, 26.21it/s]
2026-06-17 05:36:43 INFO replace_modules.py L387: Replaced 40 modules
2026-06-17 05:36:43 INFO memory.py L498: [Memory Monitor] After applying custom replacements: 'peak_ram': 1.11GB
[transformers] `loss_type=None` was set in the config but it is unrecognized. Using the default loss: `ForCausalLMLoss`.
2026-06-17 05:36:45 INFO replace_modules.py L120: Experts (after replacement) [model.layers.0.mlp.experts] (SequentialQwen3_5MoeExperts):
SequentialQwen3_5MoeExperts(
  (0-255): 256 x Qwen3_5MoeMLP(
    (gate_proj): Linear(in_features=2048, out_features=512, bias=False)
    (up_proj): Linear(in_features=2048, out_features=512, bias=False)
    (down_proj): Linear(in_features=512, out_features=2048, bias=False)
2026-06-17 05:36:45 INFO base.py L407: Using predefined ignore_layers: model.layers.[0-39].mlp.gate
2026-06-17 05:36:45 INFO utils.py L640: Ignored layers: model.layers.[0-39].mlp.gate
2026-06-17 05:36:46 INFO base.py L843: OffloadManager: offload mode (save to temp directory)
2026-06-17 05:36:49 INFO data_driven.py L693: start to cache block inputs
2026-06-17 05:36:49 INFO calib_dataset.py L1159: Preprocessing calibration dataset in a subprocess to avoid memory leaks...
Map: 100%|██████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 41555.78 examples/s]
Map: 100%|███████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 4413.81 examples/s]
Filter: 100%|███████████████████████████████████████████████████████████████████████████████████████████████| 544/544 [00:00<00:00, 969.31 examples/s]
Casting the dataset: 100%|██████████████████████████████████████████████████████████████████████████████████| 538/538 [00:01<00:00, 313.94 examples/s]
Map: 100%|██████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 40618.49 examples/s]
Map: 100%|███████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 4305.61 examples/s]
Filter: 100%|███████████████████████████████████████████████████████████████████████████████████████████████| 544/544 [00:00<00:00, 973.91 examples/s]
Casting the dataset: 100%|██████████████████████████████████████████████████████████████████████████████████| 538/538 [00:01<00:00, 351.10 examples/s]
2026-06-17 05:37:11 INFO data_driven.py L716: caching done
Quantizing model.layers.0:  0%|░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░|0/40
Fascinating work, aligns with a small project I have and now I’ll be doing some of it on the Spark because of it. Thank you very much for sharing.
Amazing to see how it is even better than the original FP16! How is that even possible! Mind blown. I am trying it on the Qwen3.6-35B-A3B model… Pointless since you are already doing it… but just for science.
I really wasn’t expecting this. I don’t understand it either.
Possibilities might include:
  • vllm is broken for fp16 and fp8
  • tool eval bench is skewing results somehow
  • fp16 has more instruction noise that quantization smooths out
  • more kernal optimisation has been invested in serving quantized models
  • The intel ‘inc’ kernel is just better written
I don’t know why, its part of the reason I released this early in development. These results don’t make sense. I was hoping for fb16 parity, I was not expecting to exceed it. This has happened with two Qwen models 0.8b and 27b – I am going to try 35b next. Eventually I want to try 3.5 122b
It will take about 14:30 hours to quantize 35b
Awesome, it does seem to be running now. Thanks for the quick fix.
I’ll try to actually quantize it in the weekend.
Exellent work! You guys are going to push DGX Spark price higher (I mean it as a compliment)
I just finished Quantizing Qwen 3.6 35B for the first time. Here is the report. I am running benchmarks now.
=== Quantization Report ===
Date: 2026-06-17 20:50:26
Version: 0.14.1
CLI Arguments:
  --batch_size 8
  --iters 1000
  --nsamples 512
  --seqlen 2048
  --output_dir ./models/Qwen3.6-35B-A3B-int4-AutoRound
Memory Summary:
  Peak RAM: 41.69 GB
  Peak VRAM: 38.82 GB
Sensitivity Analysis:
Layer                                    Cosine Sim  PSNR (dB)      Iters              uLoss   Status
🟢 model.layers.0                               0.9994       62.3        684       11.14 → 0.48     PASS
🟢 model.layers.1                               0.9994       63.1        947        3.36 → 0.74     PASS
🟢 model.layers.2                               0.9994       67.0        993        6.66 → 1.26     PASS
🟢 model.layers.3                               0.9990       62.1        421        8.40 → 2.31     PASS
🟢 model.layers.4                               0.9989       61.7        760        5.99 → 2.75     PASS
🟢 model.layers.5                               0.9987       61.0        883        8.06 → 3.54     PASS
🟢 model.layers.6                               0.9988       72.1        950        8.76 → 4.07     PASS
🟢 model.layers.7                               0.9979       67.8        944       14.31 → 6.46     PASS
🟢 model.layers.8                               0.9977       66.4        765       13.33 → 7.38     PASS
🟢 model.layers.9                               0.9977       65.6        970       15.10 → 8.80     PASS
🟢 model.layers.10                              0.9981       80.4        898      23.48 → 10.74     PASS
🟢 model.layers.11                              0.9975       79.2        995      29.37 → 13.89     PASS
🟢 model.layers.12                              0.9973       79.1        946      23.84 → 14.30     PASS
🟢 model.layers.13                              0.9969       78.1        812      26.28 → 17.91     PASS
🟢 model.layers.14                              0.9973       77.6        798      33.64 → 20.28     PASS
🟢 model.layers.15                              0.9955       75.9        674      50.15 → 28.37     PASS
🟢 model.layers.16                              0.9953       75.2        967      55.53 → 33.30     PASS
🟢 model.layers.17                              0.9946       74.6        467      59.47 → 35.88     PASS
🟢 model.layers.18                              0.9945       73.3        839      79.88 → 51.00     PASS
🟢 model.layers.19                              0.9924       71.7        362     104.94 → 71.95     PASS
🟢 model.layers.20                              0.9926       71.7        555      98.18 → 73.29     PASS
🟢 model.layers.21                              0.9923       71.4        824     117.57 → 74.99     PASS
🟢 model.layers.22                              0.9915       69.7        907    186.60 → 106.11     PASS
🟠 model.layers.23                              0.9894       69.1        783    192.03 → 131.24     WARN
🟠 model.layers.24                              0.9892       69.1        885    166.91 → 130.72     WARN
🟠 model.layers.25                              0.9885       68.5        310    196.08 → 150.31     WARN
🟢 model.layers.26                              0.9900       68.2        584    217.66 → 158.01     PASS
🟠 model.layers.27                              0.9880       67.4        382    269.98 → 186.95     WARN
🟠 model.layers.28                              0.9893       67.3        786    286.51 → 204.30     WARN
🟠 model.layers.29                              0.9893       67.3        828    299.38 → 198.03     WARN
🟠 model.layers.30                              0.9900       66.4        739    327.99 → 235.18     WARN
🟠 model.layers.31                              0.9882       49.0        882    424.14 → 302.32     WARN
🟠 model.layers.32                              0.9879       47.8        783    456.14 → 326.36     WARN
🟠 model.layers.33                              0.9893       48.7        231    631.92 → 421.33     WARN
🟠 model.layers.34                              0.9892       58.2        806    826.51 → 561.06     WARN
🟠 model.layers.35                              0.9889       49.0        663   1100.02 → 726.44     WARN
🟠 model.layers.36                              0.9884       48.0        913   1188.17 → 872.80     WARN
🟠 model.layers.37                              0.9897       48.3        482  1626.04 → 1067.69     WARN
🟢 model.layers.38                              0.9905       55.5        503  2267.83 → 1566.12     PASS
🟢 model.layers.39                              0.9906       54.4        335  3365.16 → 2042.25     PASS
Summary:
  Total blocks: 40
  Passed (🟢): 26
  Warning (🟠): 14
Thresholds: Cosine Similarity < 0.99, PSNR < 45.0 dB
This is awesome, doc!
I will be quantizing 35B myself tonight and bench/compare it to my current usuals (122b hybrid and 35B FP8/NVFP4).
I’m curious on what difference do you see in your workload between the standard 122b-a10b-int4-AutoRound vs your custom quantized version of it or Albond’s Hybrid approach (if any)?
Thanks for this :)
Here is the spark-auto-round quantized version of Qwen3.6-35B-A3B:
cyburn/Qwen3.6-35B-A3B-int4-AutoRound · Hugging Face
DON’T use for now… not working… need some fixing.
Just in case you run into a problem loading – there was a regression error I fixed with the last change, but it depends which repo you pulled.
Here is a python script you can run: fix-v14.1-layer-prefix.py
Once I have a chance to run the quantized model I will post the correct json files for 35b in a zip that you can drop in.
There are also scripts and example recipes in spark-auto-round/spark-vllm-docker to launch local models using using community docker recipes with the run-local-recipe.sh script.
I am running in an issue… I think spark-auto-round is quantizing the ViT linear layers and this is breaking things in vllm:
Proper: exclude the ViT from quantization in AutoRound
The ViT linear layers (visual.*) shouldn’t be quantized — they cause these kernel compatibility issues. In your AutoRound quantization call, add the ViT to the excluded layers. Let me check what the start script looks like.
I have a queue of jobs running at the moment, everything takes so long to run, I am working through the models systematically, I will let you know if I uncover anything else.
The 27b multi-modal model was working in my transcription pipeline. So I know it works, I just think I broke something fixing the 35b MOE.
I tried it on Qwen/Qwen3.5-122B-A10B, but it errored out..
(spark-auto-round) mike@pgx:~/spark-auto-round$ spark-auto-round --dataset “opencode-instruct” Qwen/Qwen3.5-122B-A10B
2026-06-17 16:28:58 INFO main.py L143: Spark Auto Round version 0.14.1
–batch_size 8
–nsamples 512
–seqlen 2048
–group_size 128
–iters 1000
–dataset opencode-instruct
2026-06-17 16:28:58 INFO main.py L169: torch.compile is enabled to reduce tuning costs. Disable with --disable_torch_compile if it causes issues.
2026-06-17 16:28:58 INFO main.py L177: start to quantize Qwen/Qwen3.5-122B-A10B
2026-06-17 16:28:58 INFO memory.py L336: Memory analysis:
Model: Qwen/Qwen3.5-122B-A10B
Parameters: 118.5B
Model size: 220.8 GB (bfloat16)
Available: 39.3 GB
Threshold: 29.4 GB (75%)
Blocks: 48 layers
Block size: ~4710 MB each
Fetching 39 files: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 39/39 [00:00<00:00, 10636.44it/s]
Loading weights: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 831/831 [00:00<00:00, 9529.46it/s]
2026-06-17 16:29:01 WARNING logging.py L340: Skipped quantization for 48 layer(s) with shape not divisible by 32: model.layers.[0-47].mlp.shared_expert_gate. These layers will run in full precision (bf16) — this is expected for small/gate layers and has negligible impact.
2026-06-17 16:29:01 INFO replace_modules.py L120: Experts (before replacement) [model.layers.0.mlp.experts] (Qwen3_5MoeExperts):
Qwen3_5MoeExperts(
2026-06-17 16:29:01 INFO memory.py L495: [Memory Monitor] Before applying custom replacements: ‘peak_ram’: 1.67GB
2026-06-17 16:29:01 INFO replace_modules.py L360: Found 48 modules to replace
Replacing modules: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 48/48 [00:01<00:00, 28.71it/s]
2026-06-17 16:29:03 INFO replace_modules.py L387: Replaced 48 modules
2026-06-17 16:29:03 INFO memory.py L498: [Memory Monitor] After applying custom replacements: ‘peak_ram’: 1.82GB
[transformers] loss_type=None was set in the config but it is unrecognized. Using the default loss: ForCausalLMLoss.
2026-06-17 16:29:05 INFO replace_modules.py L120: Experts (after replacement) [model.layers.0.mlp.experts] (SequentialQwen3_5MoeExperts):
(gate_proj): Linear(in_features=3072, out_features=1024, bias=False)
(up_proj): Linear(in_features=3072, out_features=1024, bias=False)
(down_proj): Linear(in_features=1024, out_features=3072, bias=False)
2026-06-17 16:29:05 INFO base.py L407: Using predefined ignore_layers: model.layers.[0-47].mlp.gate
2026-06-17 16:29:05 INFO utils.py L640: Ignored layers: model.layers.[0-47].mlp.gate
2026-06-17 16:29:07 INFO base.py L843: OffloadManager: offload mode (save to temp directory)
2026-06-17 16:29:11 INFO data_driven.py L693: start to cache block inputs
2026-06-17 16:29:11 INFO calib_dataset.py L1159: Preprocessing calibration dataset in a subprocess to avoid memory leaks…
Map: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 45473.99 examples/s]
Map: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 4459.86 examples/s]
Filter: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 544/544 [00:00<00:00, 961.00 examples/s]
Casting the dataset: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████| 538/538 [00:01<00:00, 469.81 examples/s]
Map: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 44558.41 examples/s]
Map: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 2100/2100 [00:00<00:00, 4645.20 examples/s]
Filter: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 544/544 [00:00<00:00, 972.70 examples/s]
Casting the dataset: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████| 538/538 [00:01<00:00, 421.94 examples/s]
File “/home/mike/spark-auto-round/.venv/bin/spark-auto-round”, line 10, in
sys.exit(run())
File “/home/mike/spark-auto-round/auto_round/main.py”, line 268, in run
start()
File “/home/mike/spark-auto-round/auto_round/main.py”, line 133, in start
tune(args)
File “/home/mike/spark-auto-round/auto_round/main.py”, line 261, in tune
File “/home/mike/spark-auto-round/auto_round/compressors/base.py”, line 1265, in quantize_and_save
self.quantize()
File “/home/mike/spark-auto-round/auto_round/compressors/data_driven.py”, line 694, in quantize
all_inputs = self.try_cache_inter_data_gpucpu(
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/torch/utils/_contextlib.py”, line 124, in decorate_context
return func(*args, **kwargs)
File “/home/mike/spark-auto-round/auto_round/compressors/data_driven.py”, line 146, in try_cache_inter_data_gpucpu
return self.calibration.collect(block_names, nsamples, layer_names=layer_names, last_cache_name=last_cache_name)
File “/home/mike/spark-auto-round/auto_round/calibration/llm.py”, line 79, in collect
all_inputs = self.cache_inter_data(
File “/home/mike/spark-auto-round/auto_round/calibration/llm.py”, line 239, in cache_inter_data
c.calib(nsamples, calib_bs)
File “/home/mike/spark-auto-round/auto_round/compressors/data_driven.py”, line 169, in calib
return self.calibration.calib(nsamples, bs)
File “/home/mike/spark-auto-round/auto_round/calibration/llm.py”, line 387, in calib
raise error
File “/home/mike/spark-auto-round/auto_round/calibration/llm.py”, line 366, in calib
c.model(**data_new, **kwargs)
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/torch/nn/modules/module.py”, line 1778, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/torch/nn/modules/module.py”, line 1789, in _call_impl
return forward_call(*args, **kwargs)
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/transformers/utils/generic.py”, line 907, in wrapper
output = func(self, *args, **kwargs)
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/transformers/models/qwen3_5_moe/modeling_qwen3_5_moe.py”, line 1858, in forward
output_router_logits if output_router_logits is not None else self.config.output_router_logits
File “/home/mike/spark-auto-round/.venv/lib/python3.12/site-packages/transformers/configuration_utils.py”, line 436, in getattribute
return super().getattribute(key)
AttributeError: ‘Qwen3_5MoeConfig’ object has no attribute ‘output_router_logits’
I am not a python dev – its like learning a foreign language to me – C and rust are my thing, so I am OK at coding but I really need agent help debugging. I think I got stuck in a loop trying to fix what I perceived was a brittle regex parser, but the error was actually in an overloaded output structure with ‘magic’ hidden state. I had to implement a full --dry-run flag that regenerates the model config files just so I could trace the error through the codebase. It seems to be producing the correct json files now. I am running one last quantize run with the 0.8b model. When I confirm its working I have a 35b here that is also broken. So the dry-run should be able to rebuild its correct configs as well. When both those load and benchmark I will push a commit.
The good news is the --dry-run setting should fix broken config files in already quantized models. I believe shards were ok, the layer names were mangled.
Once the broken config files are fixed I will look into loading the larger 122b model.
Some updates:
I rebuilt the multi-modal mllm support in Spark Auto Round. Previously it just ignored the layers and left them at fb16, but for whatever reason this was working and it broke. So I just copied the upstream auto-round handler code over, wired it in and that appears to have fixed the vision layers in Qwen. I am currently quantizing 35b, it has about 4 hours to go. When its done I will benchmark, test visions layers and report back.
I still don’t trust the results I am seeing. I went back an tweaked all the vllm recipes. I managed to get better fp16 scores out of the Qwen 3.5 0.8b test model. Nevertheless the Spark Auto Round with nvidia/OpenCode Instruct dataset still repeatedly out performs fp16 on this model by 1%.
The real kicker is that SAR is 7% better than the intel auto-round.
Adaptive Sensitivity-Aware Quantization (ASAQ)
I still haven’t given up on this idea. Maybe vllm was mis-configured. Maybe with the right recipe it will work. It is integrated into the repo. I am working on documentation for it now. It is a seperate cli tool. You run it the same way spark-asqa-substitute <model>. I reads the quantization-report.csv and substitutes sensitive layers with fp16 layers from the original model. For MOE it performs Router Jaccard Similarity to detect routing instability caused by quantization. The router (gating layer) decides which experts process each token. Quantization noise can flip these decisions, causing cascading quality degradation even if individual expert layers have high cosine similarity.
I just need 35b to test this with… Stay tuned ;)
Here are some preliminary results. I only did one rep of each. Adding --dtype=bfloat16 resulted in the highest score. Prefix caching with speculative decoding is still broken.
Results with Qwen 3.6 35b a3b
🥇 qwen3.6-35b-sar-bf16 int4 OpenCode Instruct 93 65.4 ★★★★★ 60/8/1 275K
🥈 qwen3.6-35b-sar-mtp int4 OpenCode Instruct 91 78.7 ★★★★★ 58/10/1 272K
🥉 qwen3.6-35b-sar int4 OpenCode Instruct 91 64.7 ★★★★★ 59/8/2 283K
4 qwen3.6-35b-sar-pc int4 OpenCode Instruct 91 64.5 ★★★★★ 59/8/2 284K
5 qwen/qwen3.6-35b bf16 - 91 28.3 ★★★★★ 59/8/2 292K
6 qwen/qwen3.6-35b-fp8 fp8 - 90 48.0 ★★★★★ 58/8/3 264K
7 qwen3.6-35b-sar-dflash int4 OpenCode Instruct 88 97.1 ★★★★ 55/11/3 282K
8 qwen3.6-35b-sar-pc-mtp-bf16 int4 OpenCode Instruct 47 73.4 ★★ 28/9/32 136K
9 qwen3.6-35b-sar-pc-mtp int4 OpenCode Instruct 44 109.1 ★★ 26/9/34 131K
10 qwen3.6-35b-sar-pc-dflash int4 OpenCode Instruct 43 102.3 ★★ 25/9/35 133K
Legend
  • -sar Spark Auto Round
  • -pc Prefix Caching
  • -mtp MTP=2 Speculative Decoding (MTP=1 with -pc)
  • -dflash DFlash=5 Speculative Decoding
  • -bf16 bfloat16 data type
