Invalid Device Ordinal
Problem
I was going through a DLI module: Asynchronous Streaming, and Visual Profiling for Accelerated Applications with CUDA C/C++: 06-stream-init and completed everything fine in the jupyter lab env.
However I wanted to make sure my system and cuda were configured correctly and am finding that the code is returning “invalid device ordinal”, but still passing the check. Could someone help me debug further?
When I add print statements deviceId returns 0. So I’m not really sure why there is a device ordinal error happening.
System
CUDA 12.3
Windows 11
VS 2022, v142
Error
Error: invalid device ordinal
Success! All values calculated correctly.
Code
#include <stdio.h>
__global__
void initWith(float num, float *a, int N)
  int index = threadIdx.x + blockIdx.x * blockDim.x;
  int stride = blockDim.x * gridDim.x;
  for(int i = index; i < N; i += stride)
    a[i] = num;
__global__
void addVectorsInto(float *result, float *a, float *b, int N)
    result[i] = a[i] + b[i];
void checkElementsAre(float target, float *vector, int N)
  for(int i = 0; i < N; i++)
    if(vector[i] != target)
      printf("FAIL: vector[%d] - %0.0f does not equal %0.0f\n", i, vector[i], target);
      exit(1);
  printf("Success! All values calculated correctly.\n");
int main()
  int deviceId;
  int numberOfSMs;
  cudaGetDevice(&deviceId);
  cudaDeviceGetAttribute(&numberOfSMs, cudaDevAttrMultiProcessorCount, deviceId);
  const int N = 2<<24;
  size_t size = N * sizeof(float);
  float *a;
  float *b;
  float *c;
  cudaMallocManaged(&a, size);
  cudaMallocManaged(&b, size);
  cudaMallocManaged(&c, size);
  cudaMemPrefetchAsync(a, size, deviceId);
  cudaMemPrefetchAsync(b, size, deviceId);
  cudaMemPrefetchAsync(c, size, deviceId);
  size_t threadsPerBlock;
  size_t numberOfBlocks;
  threadsPerBlock = 256;
  numberOfBlocks = 32 * numberOfSMs;
  cudaError_t addVectorsErr;
  cudaError_t asyncErr;
   * Create 3 streams to run initialize the 3 data vectors in parallel.
  cudaStream_t stream1, stream2, stream3;
  cudaStreamCreate(&stream1);
  cudaStreamCreate(&stream2);
  cudaStreamCreate(&stream3);
   * Give each `initWith` launch its own non-standard stream.
  initWith<<<numberOfBlocks, threadsPerBlock, 0, stream1>>>(3, a, N);
  initWith<<<numberOfBlocks, threadsPerBlock, 0, stream2>>>(4, b, N);
  initWith<<<numberOfBlocks, threadsPerBlock, 0, stream3>>>(0, c, N);
  addVectorsInto<<<numberOfBlocks, threadsPerBlock>>>(c, a, b, N);
  addVectorsErr = cudaGetLastError();
  if(addVectorsErr != cudaSuccess) printf("Error: %s\n", cudaGetErrorString(addVectorsErr));
  asyncErr = cudaDeviceSynchronize();
  if(asyncErr != cudaSuccess) printf("Error: %s\n", cudaGetErrorString(asyncErr));
  cudaMemPrefetchAsync(c, size, cudaCpuDeviceId);
  checkElementsAre(7, c, N);
   * Destroy streams when they are no longer needed.
  cudaStreamDestroy(stream1);
  cudaStreamDestroy(stream2);
  cudaStreamDestroy(stream3);
  cudaFree(a);
  cudaFree(b);
  cudaFree(c);
windows doesn’t permit prefetching. It doesn’t have the same unified memory model that you find on linux.
So if you comment out the cudaMemPrefetchAsync() calls, the remainder should be fine.
You can read about it in the managed/unified memory section of the programming guide.
In a nutshell, on windows, the UM system behaves differently. General behavior is that all managed allocations are migrated to the device at the point of kernel launch, and become accessible to host code again after a subsequent cudaDeviceSynchronize() call.
I would also suggest you may want to add full CUDA error checking so that you can see where the errors are “first visible” i.e. what call is reporting them (first).
