I am using Riva 2.7.0 for ASR. I want to add inverse text normalization to the current pipeline.[English T5-based Inverse Text Normalization | NVIDIA NGC](https://English T5-based Inverse Text Normalization) model available is available for ITN but with nemo. Will the next Riva releases will have ITN available?
Are there any documentation that I can refer to if I am looking to use the above model with Riva ASR?
HI @ayush.raj
Thanks for your interest in Riva,
I will check with the internal team on your question and let you know
Hi @ayush.raj
I have some updates from the team,
Riva support WFST based ITN today, Would like to know what is needed that non-neural WFST based ITN does not do?
I’m also looking for neural based ITN. Having to describe the WFST rules is extremely complex. Given sufficient training data, the neural based approach should be much simpler.
