IOR runtime error while compiled with Mellanox OpenMPI on SR-IOV + KVM environment
[root@vcn01 C]# export PATH=/usr/mpi/gcc/openmpi-3.1.0rc2/bin:$PATH
[root@vcn01 C]# export LD_LIBRARY_PATH=/usr/mpi/gcc/openmpi-3.1.0rc2/lib64:$LD_LIBRARY_PATH
[root@vcn01 C]# export INCLUDE=/usr/mpi/gcc/openmpi-3.1.0rc2/include:$INCLUDE
[root@vcn01 C]# gmake posix mpiio
mpicc -o IOR IOR.o utilities.o parse_options.o \
aiori-POSIX.o aiori-noMPIIO.o aiori-noHDF5.o aiori-noNCMPI.o \
-lm
aiori-POSIX.o aiori-MPIIO.o aiori-noHDF5.o aiori-noNCMPI.o \
-lm
[root@vcn01 C]# ./IOR
WARNING: No preset parameters were found for the device that Open MPI
detected:
Local host: vcn01
Device name: mlx5_0
Device vendor ID: 0x02c9
Device vendor part ID: 4114
Default device parameters will be used, which may result in lower
performance. You can edit any of the files specified by the
btl_openib_device_param_files MCA parameter to set values for your
device.
NOTE: You can turn off this warning by setting the MCA parameter
btl_openib_warn_no_device_params_found to 0.
[1520843760.041971] [vcn01:20166:0] cpu.c:52 UCX WARN CPU does not support invariant TSC, time may be unstable
[vcn01:20166:0] Caught signal 11 (Segmentation fault)
==== backtrace ====
2 0x000000000006858c mxm_handle_error() /var/tmp/OFED_topdir/BUILD/mxm-3.7.3111/src/mxm/util/debug/debug.c:641
3 0x0000000000068adc mxm_error_signal_handler() /var/tmp/OFED_topdir/BUILD/mxm-3.7.3111/src/mxm/util/debug/debug.c:616
4 0x0000000000035250 killpg() ??:0
5 0x000000000005f2d0 PMPI_Comm_set_name() ??:0
6 0x000000000005f2d0 PMPI_Comm_size() /var/tmp/OFED_topdir/BUILD/openmpi-3.1.0rc2/ompi/mpi/c/profile/pcomm_size.c:63
7 0x0000000000402a2f main() /mnt/lustre_client/pasokan/IOR-July12/src/C/IOR.c:126
8 0x0000000000021b35 __libc_start_main() ??:0
9 0x00000000004027f9 _start() ??:0
Segmentation fault
[root@vcn01 C]#
