Is < 100k context benchmaxxing or viable for you?
Spark platforms are starting to hit the ~100 tk/s range, but I’ve anecdotally noticed the io being around 4k, or context output being glazed over as under a usable coding reliability test, compact degradation etc.
Quants are one thing, but performant real-world usability is generally avoided in showcase metrics. This is always a disconcerting performance metric for any hardware.
Latently, what are spark users qualifying as their ‘I can use that reliably for X project’?
Mine is 5x compacts with > 200k context output. What’s yours?
My used context in Hermes running DSv4.1F is regularly around 700k used. With a max context of 1M useable I have a decent margin spare.
With GLM 5.3 flash I typically run over 100k context in just text chat and it often starts loosing the needle in the haystack at that point. Anything agentic I hit 100k sometimes within a few minutes and sometimes before it even outputs one line of code so I cant really see anything below 300k of context being usable for agentic work.
with my dual spark cluster I noticed that things get less reliable after 500k
I totally agree though that benchmarks that are using greedy decoding with T=0 and no thinking etc with small amounts of prefill are not super relevant to what it really is like when you use it in your harness
I am starting to see some recipes supply benchmarks that specify what temp and effort they were using along with context and that makes it a lot more meaningful for me to estimate what it will really feel like in my harness once I set it up, or even if I should skip it
This is a very relevant question, particularly when moving from impressive benchmark numbers to real production workloads.
We’re running a Qwen3.5 122B model on a single DGX Spark as part of a multilingual automotive product catalogue translation pipeline.
Our workload involves thousands of structured product records, technical terminology, consistency checks and automated quality validation.
What we’ve learned is that tokens per second and maximum advertised context length are not sufficient measures of practical usefulness.
For our use case, the more meaningful questions are:
  • Does the model consistently preserve technical meaning and terminology?
  • Does it produce valid structured output without silently dropping fields?
  • Can it maintain quality across repeated tasks and larger inputs?
  • How many completed, validated records can we process per hour?
  • What happens under concurrent requests?
That last point exposed an interesting limitation in our setup.
With Ollama 0.34.0 and OLLAMA_NUM_PARALLEL=2, our Qwen3.5 MoE model still ran with a single inference slot (-np 1). A single test request completed in 7.7 seconds, while two simultaneous requests took approximately 15.2 seconds in total — effectively serialized.
So even when memory capacity appears sufficient, actual workload throughput can be constrained by the runtime.
We haven’t yet established a reliable context-length degradation threshold for this model, and I wouldn’t want to extrapolate one from these results.
For long-running agent workflows, we also rely on external persistent state and checkpoints instead of assuming that an extremely large context window alone guarantees continuity.
I would be very interested in benchmarks that combine context length, task success rate, structured-output correctness, concurrency and quality degradation after repeated agent steps.
That’s the kind of benchmark that would help us decide whether a model is genuinely useful for production work, rather than simply impressive on paper.
I’ve only ever noticed it start getting weird around 500k, if that. Not sure what quant you’re using.
If you’re using one of the many Tensorfold variants out there, I recommend setting dense layers to FP8 instead of Q4. IMO it makes a noticeable difference for that. Frankly I refuse to use Q4 even if it’s faster. At FP8 it’s been very reliable at high context work.
Could be because all of my work is multimodal and diffusion AI model development and these models are just not very good at it. I’ve not found one that’s reliable for spatiotemporal reasoning.
I agree with Revolut - long context is a scam. My sweet spot is 262k for coding, twice that and I can see quality degradation (running deepseek 4.1-flash 2.9bpw 1017 on 2xDGX these days, but this seems about right regardless of quantization)
Better question: is having longer context available, even with some understood limitations, better than doing the same task with 4-8 compactions along the way?
In my experience, it is. Most of my work is done under 500k - but when I stretch above, I recall how badly multiple compactions hurt the progress and process of what I used to develop back when most models were 128k. An occasional oversight (which generally gets rapidly corrected) is peanuts compared to what I used to struggle with across compactions.
Some of this is models getting better, but I felt the same with Qwen 3.8-27B with limited context on a 3090 when my Sparks were down.
I will admit this could in part be due to the compaction method itself, but regardless it’s always going to be lossy.
I find the lossy-ness of the compaction is an area that requires significant overhaul. With a rolling-window-bibliography of documentation, I can see it instead being a more physical version of training quantification.
For example, my general best-practice is to set a rule where the model placates me with updating a hub and spoke doc set at N compaction (usually 4-5 if I don’t ask it for one earlier).
Since DS4.1 and Q38fn, it hasn’t missed much and hallucinating critical needle-depth architecture is less and less of an issue. However, this is a practice that starts at project inception; whereas a post-hoc doc set can be prone to model assumptions leading to vague elucidation. To be fair, a few iterations of doc building is pretty good.
I am running GLM 5.3 for coding and I often get to 850k, 900k and 950k without a problem. I find I run into problems when my instructions are misdrafted, then the session can go sideways after that. By misdrafted, I mean the instructions don’t make actual sense or cause confusion. The model then seems to get confused and the session will be messed up after that. So, I am super careful with my instructions.
I noticed subpar results in Hermes with compaction. I was seriously thinking about turning it off and emitting a warning at 512k telling me I should wrap it up and switch to a new session
Has anyone tried to just get rid of auto-compaction entirely and lean on 1M context as insurance?
You would probably have to ask the model to create a handover checkpoint to the next session, which it can probably do better than a generic compaction routine
I am using hermes without any compaction that I have noticed so that may help.
