I have this attached pattern in my code a lot. Basically it amounts to a first kernel for filtering a large dataset, where the selected entries returned will be very sparse, and then a second kernel for performing a much more involved computation on the much-reduced dataset.
It seems like the cudaStreamSynchronize is almost superfluous, but I can’t see any way around it. Is there an alternative pattern that helps here? Does CUDA dynamic parallelism help in any way?
/* Pseudocode. Please ignore silly mistakes/syntax and inefficiant/incorrect simplifications */
__global__ void bar( const float * dataIn, float * dataOut, unsigned int * counter_ptr )
< do some computation >
if (bConditionalComputedAboveIsTrue)
const unsigned int ind = atomicInc(counter_ptr, (unsigned int)(-1));
dataOut[ ind ] = resultOfAboveComputation;
int foo( float * d_datain, float* d_tempbuffer, float* d_output, cudaStream_t stream ){
/* Initialize a counter that will be updated by the bar kernel */
unsigned int * counter_ptr;
cudaMalloc( &counter_ptr, sizeof( unsigned int) ); //< Create a Counter
cudaMemsetAsync(counter_ptr, 0, sizeof(unsigned int), stream); //<Initially Set the Counter to 0
dim3 threadsInit(16,16,1);
dim3 gridInit(256, 1, 1);
/* Launch the Filtering Kernel. This will update the value in counter_ptr*/
bar<<< gridInit, threadsInit, 0, stream >>>( d_datain, d_tempbuffer, counter_ptr );
/* Download the count and synchronize the stream */
unsigned int count;
cudaMemcpyAsync(&count, counter_ptr, sizeof(unsigned int), cudaMemcpyDeviceToHost, stream);
cudaStreamSynchronize( stream ); //< Is there any way around this synchronize?
/* Compute the grid parameters and launch a second kernel */
dim3 bazThreads(128,1,1);
dim3 bazGrid( count/128 + 1, 1, 1); //< Here I use the counter modified in the prior kernel to set the grid parameters
baz<<< bazGrid, bazThreads, 0, stream >>>( d_tempbuffer, d_output );
/* cleanup */
cudaFree(counter_ptr);
