Can you try opening a command-line with shortcut “x64 Native Tools Command Prompt for VS 2019” (should be located in C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Visual Studio 2019\Visual Studio Tools\VC
)? Invoking nvcc.exe
from your CUDA toolkit should work just fine then.
Thank you for your patience. Here too the error is not suppressed.
output.txt (930 Bytes)
Hi aladram. Just wondering if you have any follow-up for me. In my last post, I attached a txt file showing that the suppressions are not working. Thank you.
Thanks for trying this! I will circle back to you ASAP
Thank you!
Thank you very much!
