Is DMA Supported Via DPDK on the Bluefield 3?
The docs on DPDK’s website make it seem like the MLX-5 drivers support DMA with DPDK but over the past week I have failed to get DPDK to recognize any DMA devices.
Also, what parameters should be supplied to EAL to get DPDK DMA working?
I’d rather use DPDK DMA as it has more features than the DOCA DMA library.
If DPDK DMA does not work with the BF3 card then what is the best way to use the DOCA DMA library? The sample code is very simplistic and does not provide any examples of how to signal the DPU that the host has read the buffer (handshaking) nor some form of a ring buffer.
ubuntu@localhost:~$ /opt/mellanox/dpdk/bin/dpdk-devbind.py --status
Network devices using kernel driver
0000:03:00.0 'MT43244 BlueField-3 integrated ConnectX-7 network controller a2dc' if=en3f0pf0sf0,p0,pf0hpf drv=mlx5_core unused=
0000:03:00.1 'MT43244 BlueField-3 integrated ConnectX-7 network controller a2dc' if=en3f1pf1sf0,pf1hpf,p1 drv=mlx5_core unused=
No 'Baseband' devices detected
No 'Crypto' devices detected
No 'DMA' devices detected
No 'Eventdev' devices detected
No 'Mempool' devices detected
No 'Compress' devices detected
No 'Misc (rawdev)' devices detected
No 'Regex' devices detected
ubuntu@localhost:~$ cat /proc/modules | grep -i dma
rdma_ucm 36864 0 - Live 0x0000000000000000 (O)
rdma_cm 122880 1 rdma_ucm, Live 0x0000000000000000 (O)
iw_cm 53248 1 rdma_cm, Live 0x0000000000000000 (O)
ib_cm 131072 2 rdma_cm,ib_ipoib, Live 0x0000000000000000 (O)
ib_uverbs 155648 5 rdma_ucm,mlx5_ib, Live 0x0000000000000000 (O)
ib_core 479232 8 rdma_ucm,rdma_cm,iw_cm,ib_ipoib,ib_cm,ib_umad,mlx5_ib,ib_uverbs, Live 0x0000000000000000 (O)
mlx_compat 20480 14 nvme_fabrics,rdma_ucm,rdma_cm,iw_cm,ib_ipoib,ib_cm,ib_umad,mlx5_ib,ib_uverbs,ib_core,mlx5_core,nvme,mlxdevm,nvme_core, Live 0x0000000000000000 (O)
I have the same problem with BF-2.
No. It should not be supported by DPDK DMA.
For DOCA DMA, refer to :
https://docs.nvidia.com/doca/sdk/doca+dma/index.html
Thank you for confirming.
We have looked into DOCA DMA but seem to only be able to do 36k transactions per second. Is there a way to access the memory map directly and implement a Ring buffer between the DPU and Host. That way both sides can read/write and we could achieve much higher throughput?
Hi
We are looking into the same. Did you manage to find a solution using DOCA dma, or did you go other routes?
Not entirely. The DOCA DMA is okay, but a bit limiting, there’s not a lot of control over it.
There is the DOCA comm channel library, but it also has some big limitations. Each message is limited to 4k bytes (page size), it’s okay but could be better.
There are the default SF (scalable functions) that can send data from the DPU to the host as a network interface but there can be packet loss with UDP if you exceed 450k pps as the ovs switch kernel cannot keep up. I haven’t seen really any other solutions outside of this (this is also limited to 65k bytes with TCP).
Hope this helps.
