I’m using our customized Orin board with JetPack 5.0.2, and when I enter the UEFI shell at startup, I can see the ifconfig command in the help command, but when I use the ‘ifconfig -l eth0’ command, there is no response. I also tried setting a static IP address using ‘ifconfig -s eth0 static …’, but it was not successful after restarting. Could you tell me how to use the ifconfig command in UEFI shell? Thank you.
Please search " IfConfig" + UEFI keyword in google search and it will lead you to how to use it.
