Here is what I saw on GPU GEMS - Chapter 8. Simulating Diffraction:
One can see the code part is a mess from my side.
Hi @ziyuang,
I am not sure how this should look. I have no way to verify without seeing the book’s content that was initially published in 2004.
I would expect something at least as above, i.e., one newline after each ;
or }
, also one newline after each {
or the )
right before each {
, depending on the style.
I have access to a scanned version and these are the relevant pages, which seem even better, as the function parameters have their own lines:
Cool! I will pass this on to the team that manages that page.
Thanks,
Tom
Thanks. I think it happens on every page with code, from GPU Gems 1 to GPU Gems 3.
Can confirm the broken code snippets are still present in all the GPU Gems book. It’s weird that this is the only thread talking about it. I thought I had something wrong with my web layout.
Have you found any fix apart from downloading the scanned version ?
Same here, I’m reading gpu gems lately and the problem still exist.
I have bumped this issue to the team that manages the site.
Thanks for your patience,
Tom
