Hallo. It is written in the OPENACC GETTING STARTED GUIDE in the section “Fortran I/O” that:
“Starting in PGI 15.5, print and write statements in device code are also supported when
used with the LLVM code generator -ta=llvm, or -Mcuda=llvm, and in combination with
the -mp compiler option.”
My question is: Is it possible to use a C function printf() inside
#pragma acc parallel{…} construct?
If no, is there any opportunity to do prints inside the parallel construct (to make prints on gpu) in C++?
Hi @and,
No, sorry. A Printf call is not available in C/C++. Also note that Fortran only supports unformatted writes within OpenACC.
-Mat
It’s a pity. As i know, printf() and cuPrintf() may be used in CUDA. It is the OpenAcc standard that does not allow to print in device code, isn’t it?
Excuse me, but i have found the information here:
https://parallel-computing.pro/index.php/11-openacc/53-using-cuda-device-functions-from-openacc.
Is it wrong?
Couldn’t You also answer another question. There is a loop in my code, which is parallelized in the following simple way:
#pragma acc parallel loop present(particles)
for(int i=0; i<LIFE; ++i)
50-80 sequential code lines, 2 or 3 small if constructions
In this loop i change the elements (from 0 to LIFE) of the array particles (on gpu). There are no dependencies between the loop iterations.
My question is: Is this way of parallelizing the loop the most efficient (i hesitate that i don’t specify the gang() and vector_length() clauses (and, may be, the worker() clause)?
Thank You.
The OpenACC standard doesn’t define this. More it’s a limitation of PGI’s implementation.
Is it wrong?
I haven’t tried this particular code, but I assume that it works. The key difference is that you’d be calling printf from CUDA, not OpenACC.
I’d just let the compiler schedule the loop. It typically does a good job, especially for a single loop level.
Of course, feel free to try various other schedules, but my most likely the compiler will automatically find the optimal schedule.
-Mat
