For multi stream video analytics, is it possible to create threads and thread blocks and do inference for every stream on a different thread using TensorRT inference engine in C++ as we wish?
Please refer below link:
https://docs.nvidia.com/deeplearning/sdk/tensorrt-best-practices/index.html#optimize-performance
Here is a tutorial for your reference for executing with multiple CUDA stream.
Deepstream SDK:
Deepstream reference apps:
First of all thanks a lot for your response.
As per the document for TensorRT and slides for Cuda streams says I created multiple streams and multiple execution context and checked the output in visual profiler.
This is the code within my inference function, where I have used BufferManager from buffer.h library which was provided with tensorrt samples.
cudaProfilerStart();
buffers.copyInputToDeviceAsync(stream1);
buffers2.copyInputToDeviceAsync(stream2);
// Execute the inference work
context->enqueue(mParams.batchSize, buffers.getDeviceBindings().data(),stream1,nullptr);
context2->enqueue(mParams.batchSize, buffers2.getDeviceBindings().data(),stream2,nullptr);
// Copy data from device output buffers to host output buffers
buffers.copyOutputToHostAsync(stream1);
buffers2.copyOutputToHostAsync(stream2);
cudaProfilerStop();
As you can see, I have separate stream, separate buffer and separate execution context to inference 2 images. But when I checked the visual profiler results both the executions (inference) did not happen simultaneously.
Can you please explain me what went wrong here?
Unless otherwise specified all calls are placed into a default stream, often referred to as “Stream 0”. It has special synchronization rules:
- Synchronous with all streams
- Operations in stream 0 cannot overlap other streams
You avoid this you need to createsStreams with non-blocking flag set
— cudaStreamCreateWithFlags(&stream,cudaStreamNonBlocking)
Please refer this link:
http://on-demand.gputechconf.com/gtc/2014/presentations/S4158-cuda-streams-best-practices-common-pitfalls.pdf
It might also be due to low GPU compute space to run multiple streams. Please check the memory consumption of each stream.
