Is my bandwidth calculation right? bandwidth
In BestPracticeGuide, it says
Effective bandwidth = (( Br + Bw ) / 10^9) / time
Theoretical Bandwidth = ( clockRate * 10^6 * (bitwidth/8) * 2 ) / 10^9
so my GTX260 216sp 's theoretical bandwidth is
( 1175 * 10^6 * (448/8) * 2) / 10^9 = 131.6 GB/s
In practice, my effective bandwidth is only 1.832 GB/s, is that too small?
[codebox] #define z_uint8 unsigned char
#define z_float32 float
#define z_int32 int
#define N 1024
#define R 1.23456789
// global var
z_uint8 G_Input[N*N];
z_uint8 G_Output[int(N*R)int(NR)];
z_float32 G_Input2[N*N];
z_float32 G_Output2[int(N*R)int(NR)];
cudaEvent_t start, stop;
float time;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord( start, 0 );
z_int32 size1 = NN, size2 = int(NR)int(NR), size3 = int(N*R);
z_float32* d_dest;
z_float32* d_src;
cudaMalloc( (void**)&d_src, size1 * sizeof(z_float32) );
cudaMalloc( (void**)&d_dest, size2 * sizeof(z_float32) );
for(z_int32 i = 0; i < size1; i++) G_Input2[i] = z_float32(G_Input[i]);
z_int32 iter = 10;
for(int i =0; i<iter;i++)
cudaMemcpy( d_src, G_Input2, size1 * sizeof(z_float32), cudaMemcpyHostToDevice);
cudaMemcpy( G_Output2, d_dest, size2 * sizeof(z_float32), cudaMemcpyDeviceToHost);
for(z_int32 i = 0; i < size2; i++) G_Output[i] = z_uint8(G_Output2[i]);
cudaFree( d_dest );
cudaFree( d_src );
cudaEventRecord( stop, 0 );
cudaEventSynchronize( stop );
cudaEventElapsedTime( &time, start, stop );
cudaEventDestroy( start );
cudaEventDestroy( stop );
printf(“Gpu time: %f miliseconds. \n”, time );
printf(“Gpu bandwidth: %f Gflops. \n”, (size1+size2)sizeof(z_float32)/1e6/timeiter );
}[/codebox]
i know that the first Bandwidth is between device memory and GPU, and the second Bandwidth is between
Host and Device memory.
so my peak rate is 250 MB/s * 16 = 4 GB/s (PCIE1.0 x16)
Now another question, is the GTX260 using PCIE1.0 or 2.0?
no, Theoretical Bandwidth = ( clockRate * 10^6 * (bitwidth/8) * 2 ) / 10^9
means transfer rate among device memory.
However your code does not measure bandwidth of device memory, you measure
  1. data transfer between host memory
this depends on FSB, and how many cores you use. you use only one core, so
bandwidth is about 2GB/s
  1. transfer between host memory and device memory
this depends on PCI express, roughly speaking, bandwidth is 1.7~2.5 GB/s for non-pinned memory
in my machine (ASUS P5Q PRO).
you must write a kernel function to measure bandwidth of device memory, for example, data copy
Thank you very much!!
In fact, i realize it myself later. :)
