Is the source code of NV OpenCV the same as the source code of opencv cuda?
I build OpenCV CUDA by this way, refer to dusty-nv/dockerfile (line88-105). And I downloaded the debfiles from https://nvidia.box.com/shared/static/5v89u6g5rb62fpz4lh0rz531ajo2t5ef.gz.
Source code is not included in debfiles. Is the source code of it the same as the source code of cuda modules from opencv/ opencv_contrib
If there is a difference, where can I get the source code.
It is same as open source code. You may run this script to download the source code and build OpenCV manually:
JEP/install_opencv4.5.0_Jetson.sh at master · AastaNV/JEP · GitHub
Hi DaneLLL,
It works for me. Thank you very much!
