Is threre any document about proper use of cudaMalloc/cudaMallocHost/gdrcopy respectively.
Seeing follow description, gdrcopy performs very well and no cons.
Thank you for describing this.
My intention is the difference between cudaMallocHost/GDRCopy.
From seeing the graph about data size and latency (*) , I realized that, for small data, it should use GDRCopy, and , for large data, it should use cudaMallocHost.
(*) for example GDRCopy page which is previously linked.
Thanks for your link to gdrcopy, something I hadn’t come across before.
In turn it linked to another document on RDMA I found useful and indirectly perhaps explains a number of problems that appear on these lists, around P2P failures on assorted hardware.
