Hi there,
I have isolated what appears to be a compiler optimization error whereby if a variables are used to create a result of type uint4 - the output the host receives is zero.
However, if changing ANY of these variables to a magic number, all results the host receives are correct.
I have also subsequently discovered that this ONLY occurs when performing a conditional test on a kernel input parameter (even if this parameter is constant)
Theory which led to this is using a texture ID to determine which texture reference to take input from (so that stream i can work on data i bound to texture reference i - although these were statically allocated as it appears you cannot have an array of texture references).
Any help on this, possible reasonings or solutions are very welcome.
Being limited to one texture (albeit 128MB in linear memory) at a time significantly undermines the capability of the hardware. - especially when wanting asynchronous copies to be performed.
Thanks in advance,
Michael.
P.S. There are comments in the kernel to help replicate the error.
Source code for host and kernel are attached as well:
SOURCE CODE FOR HOST
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <time.h>
// includes, kernels
#include <cuda_kernel.cu>
// prototypes
void allocate_host(void ** data, int size);
void allocate_dev(void ** data, int size);
void error_check(cudaError_t result);
void load_input_data_to_GPU_tex_mem(unsigned char * in_array, void * dev_ptr, cudaChannelFormatDesc * cd, texture<uchar4, 1, cudaReadModeElementType> * tex, unsigned int size);
void setup_exec_config_and_run_kernel(int num_threads, int num_blocks, uint4 * output, unsigned int index_range, unsigned int tex_id);
void gen_char_data(unsigned char * data, unsigned int size);
// Program main
int
main( int argc, char** argv)
//initialise CUDA device
CUT_DEVICE_INIT(argc, argv);
/******************* initialise input data parameters ****************************/
const unsigned int N = 1*1024*1024;
const unsigned int num_threads = 512;
const unsigned int index_range = 256;
const unsigned int divisor = num_threads * index_range;
const unsigned int num_blocks = N / divisor + (N%divisor == 0 ? 0:1);
/***************** allocate memory on host for input *******************************/
unsigned char * host_input;
allocate_host((void **) &host_input,N);
/***************** allocate memory on device for input *****************************/
unsigned char * dev_input;
allocate_dev((void **) &dev_input, N);
/***************** allocate memory on host for output ******************************/
const unsigned int output_size = N*sizeof(uint4);
void * host_output;
allocate_host((void **) &host_output,output_size);
/***************** allocate memory on device for output ****************************/
uint4 * dev_output;
allocate_dev((void **) &dev_output,output_size);
/***************** setup texture memory and read format *********************/
input_texture1.addressMode[0] = cudaAddressModeClamp;
input_texture1.addressMode[1] = cudaAddressModeClamp;
input_texture1.filterMode = cudaFilterModePoint;
input_texture1.normalized = 0;
//channel format description parameters x, y, z and w specify the number of bits for each component of the resulting texture fetch
//this allows ability to split fetch (4 bytes) into 1, 2, 3 or 4 individual components which can be independantly addressed
cudaChannelFormatDesc input_cd = cudaCreateChannelDesc(8, 8, 8, 8, cudaChannelFormatKindUnsigned);
/***************** setup test procedure *******************************************/
gen_char_data(host_input,N);
load_input_data_to_GPU_tex_mem(host_input,dev_input,&input_cd,&input_texture1,N);
//setup execution parameters and run kernel
setup_exec_config_and_run_kernel(num_threads,num_blocks,dev_output,index_range,1);
cudaError_t result = CUDA_SAFE_CALL(cudaMemcpy(host_output,dev_output,output_size,cudaMemcpyDeviceToHost));
error_check(result);
/******************** Test procedure complete ***********************/
/******************** Output results ********************************/
uint4 * res = (uint4 *) host_output;
for (int i=0; i<5; i++)
printf("----------------------\n");
printf("index %d:\n",i);
printf("x: %u\n", res[i].x);
printf("y: %u\n",res[i].y);
printf("z: %u\n",res[i].z);
printf("w: %u\n",res[i].w);
/******************** cleanup *****************************************/
CUDA_SAFE_CALL(cudaFreeHost(host_output));
CUDA_SAFE_CALL(cudaFree(dev_output));
CUT_EXIT(argc, argv);
- error_check
- Test ‘result’ and report either success or failure.
- In the event of failure, CUDA-specific error information is also given
if (result == cudaSuccess)
// printf(“success\n”);
else if (result == cudaErrorInvalidValue)
printf(“Invalid value\n”);
exit(1);
else if (result == cudaErrorInvalidDevicePointer)
printf(“Invalid device pointer\n”);
exit(1);
else if (result == cudaErrorInvalidTexture)
printf(“invalid texture\n”);
exit(1);
else if (result == cudaErrorInvalidMemcpyDirection)
printf(“Invalid copy direction\n”);
exit(1);
else
printf(“%s\n”,cudaGetErrorString(result));
exit(1);
- allocate_host
- allocates memory required by ‘size’ bytes to start address ‘data’
- initialises all locations to 0
cudaError_t result = CUDA_SAFE_CALL(cudaMallocHost(data,size));
memset(*data,0,size);
- allocate_dev
- reports success or failure with any relevant CUDA-specific information
cudaError_t result = CUDA_SAFE_CALL(cudaMalloc(data, size));
cudaMemset(*data,0,size);
dim3 dimBlock(num_threads,1,1);
dim3 dimGrid(num_blocks,1,1);
my_kernel<<<dimGrid,dimBlock>>>(tex_id, index_range, output);
CUT_CHECK_ERROR("Kernel execution Failed");
void load_input_data_to_GPU_tex_mem(unsigned char * in_array, void * dev_ptr, cudaChannelFormatDesc* cd, texture<uchar4, 1, cudaReadModeElementType> *tex, unsigned int size)
if (in_array == NULL)
printf (“Input data array is NULL\n”);
exit(1);
if (dev_ptr == NULL)
printf(“Device pointer points to NULL\n”);
exit(1);
if (tex == NULL)
printf(“Texture reference points to NULL\n”);
exit(1);
//copy memory to device memory
cudaError_t result = CUDA_SAFE_CALL(cudaMemcpy(dev_ptr,(void*) in_array,size,cudaMemcpyHostToDevice));
//bind memory to texture reference
result = CUDA_SAFE_CALL(cudaBindTexture(NULL,tex,(void*) dev_ptr, cd, size));
void
for (unsigned int i=0; i<size; i++)
data[i] = 'z';
for (unsigned int i=0; i<size; i+=500)
data[i] = 'A';
data[i+1] = 'A';
data[i+2] = 'B';
data[i+3] = 'B';
data[i+4] = 'C';
SOURCE CODE FOR KERNEL
#ifndef CUDA_KERNEL_H
#define CUDA_KERNEL_H
#include <cutil.h>
#include <stdio.h>
#include <math.h>
// declare texture reference for 1D unsigned char texture
texture<uchar4, 1, cudaReadModeElementType> input_texture1;
#define SDATA( index) CUT_BANK_CHECKER(sdata, index)
device void write_result(unsigned int flag, uint4 * result, unsigned int result_index, uint4 * results_array)
if (!flag)
else
results_array[result_index] = *result;
global void my_kernel(unsigned int tex_id, unsigned short index_range, uint4 * output_data)
//setup index location for each thread
unsigned int start_index = blockIdx.x * blockDim.x * index_range + threadIdx.x * index_range;
uint4 result;
//flags to indicate whether a 'A' is detected
unsigned int flag;
//current index location in texture
unsigned int input_index = start_index;
//4 bytes of data
uchar4 ch;
//track number of bytes processed
unsigned int bytes_processed = 0;
//while thread has not completed its range of input bytes to test...
while (bytes_processed < index_range)
//retrieve next input character set (uchar4)
- This test will always evaluate to true given the constant input from the host
- However, if this test is removed (leaving “ch = tex1d…index);” ), the output result
- below is correct
if (tex_id == 1)
ch = tex1Dfetch(input_texture1,input_index);
- input stream = AABBCzzzzzzzzzz…AABBCzzz… etc
- when an A is detected, result should be initialised with the given values.
if (ch.x == 'A')
* This set of values will always work, regardless of the test (tex_id == 1) condition above.
* Adding ANY constant term to ANY of the 4 fields (as in the '3' below) results in correct operation
* HOWEVER, if ALL fields are based on ANY variable available to the kernel, operation fails. (see second comment)
result.x = blockDim.x;
result.y = 3;
result.z = threadIdx.x;
result.w = start_index + bytes_processed;
flag = 1;
* This set will ONLY work when the test (tex_id == 1) is disabled.
* compare with test enabled to see difference
// result.x = blockDim.x;
// result.y = blockIdx.x;
// result.z = threadIdx.x;
// result.w = start_index + bytes_processed;
// flag = 1;
* General comment
* Is this an issue with texture memory reading or compiler optimization (when no constants are used)
* If you declare (statically) n textures and perform a switch test on tex_id the results are only output correctly
* when a constant term is used in any field of 'result'
* I hope this is enough information for a solution to be found. (or at least a reason as to why this happens)
* Thanks.
write_result(flag,&result,0,output_data);
flag = 0;
//update input index
input_index++;
//update progress through buffer
bytes_processed+=4;
