See the below code…
// functions…
device void Add(int* a, int* B );
device void Subtract(int* a, int* B );
device void Division(int* a, int* B );
//kernal function
global void FunctionPointers(int* result);
//function pointer
void (* ptrToFun)(int* x, int* y);
/ ADD() /
device void Add(int a, int B )
*a = *a + *b;
printf("\nAdd result is %2d\n", *a);
/ Subtract() /
device void Subtract(int a, int B )
*a = *a - *b;
printf("\mSubtract result is %2d\n", *a);
/ Division() /
device void Division(int a, int B )
if( *b == 0 )
return;
*a = (int)(*a)/(*B );
printf("\nDivision result is %2d\n", *a);
/ Example /
global static void FunctionPointers(int result)
ptrToFun = &Division;
int a=2,b=5;
ptrToFun(&a,&b);
*result = a;
/ HelloCUDA /
int main(int argc, char argv)
CUT_DEVICE_INIT(argc, argv);
int* device_result = 0;
CUDA_SAFE_CALL( cudaMalloc((void**) &device_result, sizeof(int)));
unsigned int timer = 0;
CUT_SAFE_CALL( cutCreateTimer( &timer));
CUT_SAFE_CALL( cutStartTimer( timer));
FunctionPointers<<<1, 1, 0>>>(device_result);
CUT_CHECK_ERROR("Kernel execution failed\n");
CUDA_SAFE_CALL( cudaThreadSynchronize() );
CUT_SAFE_CALL( cutStopTimer( timer));
printf("Processing time: %f (ms)\n", cutGetTimerValue( timer));
CUT_SAFE_CALL( cutDeleteTimer( timer));
int host_result;
CUDA_SAFE_CALL( cudaMemcpy(&host_result, device_result, sizeof(int), cudaMemcpyDeviceToHost));
if( host_result )
printf("\nFunction Pointer concept checked successfully\n");
else
printf("\nFunction Pointer concept checking failed\n");
CUDA_SAFE_CALL( cudaFree(device_result));
CUT_EXIT(argc, argv);
return 0;
now My questions are…
1) The handling of function pointers is correct in the above program??
2) Can I call printf() function from device function?
Please answer my questions.
Manjunath
