I have an Asus P5N-D motherboard (chipset: nforce 750i) and a 8800GTS 512 (G92). Also an E5200 CPU. I’m seeing about 3.1 GB/s device to host and host to device bandwidth with pinned memory and about 1.3 GB/s with pageable memory (32 megs of data in bandwidthTest).
Isn’t this a little low? I’ve had around 2.3 GB/s pinned and 0.9 GB/s pageable with my old PCIe 1.1 motherboard, I was expecting at least 4-4.5 GB/s practical bandwidth on 2.0.
780i only performs at ~4 GiB/s. It is still castrated because their “2” PCIE2.0 16x slots are fed from the NF200 chipset which is connected to the NB through another set of overclocked PCIE channels…
Most likely, yes. Most users on the forums report ~6 GiB/s with intel boards.
Looks like P45 has 16 lanes, total. On newegg it says you can enable crossfire and use the two slots as x8. The black slot is always x8. Probably in the BIOS you’ve enabled the black slot and now the the blue slot is also x8. Disable the black slot.
For what it’s worth, I’ve got a nVidia 790i board with two GX2 cards with an Intel Q9450 @2.66 GHz (1.33 GHz FSB). I get 5.7 GB/sec from CPU to GPU and 5.0 GB/sec from GPU to CPU for long transfers (64 MB) using pinned memory. No special coding tricks, and no bandwidth improvement from using both cards.
Well if your ram is only working single-channel, that could do it. I think the issue is that the blue slot isn’t getting its 16 lanes. I guess it’s supposed to be automatic, but looks like it’s stuck and there’s no way to force it. Sorry about your luck. If you’re feeling adventurous, you can up your PCIe frequency and see if that boosts bandwidth. (In the BIOS it can be overclocked 80%. I wonder what the nvidia card can take?) That could also rule out RAM and other bottlenecks.
For bandwidthTest parameters, you have to open up its source.
I’ve tried some benchmarks on my RAM and they give varying results. The most optimistic reads/writes are about 2.7GB/s. This is obviously RAM<->CPU, not RAM<->GPU but if the former is that slow, can this be an indication of the bottleneck?
Did you try memtest86+? It doesn’t need an OS and will give you the true bandwidth (I think it can also explicitly check if dual channel is enabled). 2.7GB/s sounds very low.
EDIT: Actually, I don’t know if it’ll show you the “true” bandwidth, but this person is getting 2.4GB/s on DDR400 dual channel: http://www.memtest.org/pics/i875-big.gif so compare your results to him.
I don’t have empty CDs handy so I can’t make memtest86+ boot disks. I’ve done some benchmarking with Everest (should be more credible than those noname benchmarks I’ve been using earlier). Here are the results
