I have an issue using bar.cta.sync and bar.cta.arrive correct for a producer and consumer model.
After reading the page here: 1. Introduction — parallel-thread-execution 8.2 documentation, I am trying to use bar.cta.sync and bar.cta.arrive to form a producer and consumer computation in shared memory. Below is an example code to achieve this functionality but it doesn’t serve my purpose. I am wondering where I did it wrong and if could anyone help me out.
The problem with the following code, the consumer read the wrong value from the shared memory.
It’s difficult to achieve full clarity when you don’t show something important like how many threads you are launching. In the future, I suggest providing complete examples. I will assume it is 128 threads in the block.
In that case, try setting your barrier count target to 128 instead of 64:
Threads increment the barrier count when they reach the barrier. Threads executing the .arrive variant do not wait at the barrier. Threads executing the .sync variant do wait at the barrier. The waiting threads are released when the sum total of threads executing either variant (for that barrier number) match the barrier count target.
If you are launching 128 threads per block, then the upper 2 warps “race ahead” past the if clause, and begin arriving at membar_sync_consumer, thereby incrementing (for each thread) the barrier count. When both of those upper two warps arrive there, your original barrier count target is satisfied, and those threads proceed past the barrier. This is entirely independent of what the first 2 warps may be doing. That is presumably not your intent. By setting the barrier count target to 128, we require the first 64 threads to have reached their membar_arrive_producer() point (and we do also require all of the upper 64 threads to arrive at the membar_sync_consumer() point) before any waiting thread is allowed to proceed past the membar_sync_consumer() point.
Hopefully this is now evident. Your second set of 64 threads satisfy the barrier count target.
Exited threads contribute to the barrier count.
In my view it should not be necessary to use PTX to achieve a producer-consumer model. This can be done directly in CUDA C++ using libcu++ barriers and cooperative groups, and there are also other libcu++ provided methods.
Thanks for your reply. I launched 128 threads per block and only 1 block. Here is my main function:
int main() {
int * buffer_in;
int * buffer_out;
int buffer_in_h[64];
int buffer_out_h[448];
for(int i=0; i<64; i++)
buffer_in_h[i] = 1;
CUDA_CHECK(cudaMalloc(&buffer_in, sizeof(int)*64));
CUDA_CHECK(cudaMalloc(&buffer_out, sizeof(int)*32*14));
CUDA_CHECK(cudaMemcpy(buffer_in, buffer_in_h, sizeof(int)*64, cudaMemcpyHostToDevice));
membar_test<<<1, 128>>>(buffer_in, buffer_out);
cudaError_t error = cudaGetLastError();
if (error != cudaSuccess) {
printf("CUDA error: %s\n", cudaGetErrorString(error));
CUDA_CHECK(cudaDeviceSynchronize());
CUDA_CHECK(cudaMemcpy(buffer_out_h, buffer_out, sizeof(int)*448, cudaMemcpyDeviceToHost));
for(int i=0; i<448; i=i+64)
std::cout << i << ": "<< buffer_out_h[i] << std::endl;
return 1;
In my case, the threads 0-63 are the producer, and 64-127 are the consumers.
So, bar.sync will increase the bar value by each thread who runs it. bar.arrive also increases the bar value by each thread that runs it. To make this producer and consumer work, I should have
"The key distinction between arrive and sync lies in the behavior when the bar value reaches b. In the case of arrive, it resets the bar value to 0 when bar equals b.
However, consider a scenario where arrive increments the bar value before sync is executed. If arrive increases the ‘bar’ value but doesn’t encounter a situation where bar equals b, it won’t have the opportunity to reset the bar value back to 0. Am I right here? If I am correct, then what should I do to fix that?
I have no idea where you got that. The key distinction in behavior is that threads executing .arrive do not wait at the barrier. Threads executing .sync do wait for “completion” to use the word in the PTX manual.
It should be self-evident from the modification I suggested, that you do not have enough threads executing the arrive variant to meet the barrier count target. Yet I maintain it is valid and correct code, and empirically also appears to work.
I don’t know that I understand the remainder, and might need an example.
It is explicitly not expected for a barrier instruction to be executed more than once by any thread in the process of completing a particular numbered barrier. Therefore positing a case where you do not have enough threads executing a barrier number in order to meet the barrier count target for that barrier is just broken code. I cannot tell you generically how to fix it, except to say you need to refactor your code so it is possible for the number of threads specified in the barrier count target to actually execute a barrier op for that numbered barrier.
Thanks a lot for your clarification. I think I do make a mistake in terms of: The key distinction between arrive and sync lies in the behavior when the bar value reaches b . In the case of arrive , it resets the bar value to 0 when bar equals b .
Both arrive and sync should reset the barrier count when it reaches the b. I guess?
Many many thanks for explaining how the sync and arrive works! It has been really helpful!
