issue while using break statement in cuda kernel
i am having a problem. My kernel has a loop which runs for say 20 times. But for most of the cases I need to break much before 20 times and hence dont need to execute other kernels. But when i use break statement all the values loaded in shared memory becomes wrong and hence i cannot use break statement.
MY question is what will happen if there is a break statement in a loop in cuda kernel. I can understand that it will cause divergence but why should this affect the final output in terms of results.
Please Help me explain this.
Regards,
Mohit
Regards,
Mohit
Do you use [font=“Courier New”]__syncthreads()[/font] inside the loop?
Yes I did, just before the end of the loop.
This won’t work, since [font=“Courier New”]__syncthreads()[/font] must be encountered by all threads in the same manner.[sup][1][/sup]
Instead of using [font=“Courier New”]break[/font] inside the loop, you can set a flag variable and then make the whole loop body excluding the [font=“Courier New”]__syncthreads()[/font] conditional depending of that variable.
[sup][1] It appears that on all current hardware actually only all warps need to encounter them, but lets keep things simple and safe for future hardware as well[/sup].
Dear Tera,
Thanks a lot for pointing out this :). This is what was causing all problem.
Dear Tera,
For threads that have finished their work, just execute the [font=“Courier New”]__syncthreads()[/font] and any data transfers to/from shared memory that may be needed by other threads, but not the rest of the loop body:
int flag = 1;
    for (int i=0; i<20; i++) {
// load data...
__syncthreads();
        if (flag) {
// do work...
if (finished) {
                // this is where the break statement would have been
                flag = 0;
         __syncthreads();
int flag = 1;
// load data...
__syncthreads();
        if (flag) {
// do work...
if (finished) {
                flag = 0;
         __syncthreads();
