I am trying to link some Fortran code to some C++ code which was compiled with gcc. The problem is that when passing the booleen (l1) to the C++ part, true values are associated to 255. This is an issue when evaluating ( ! l1), as it is then 254 which is still true. I have made a small example to illustrate the problem:
Main.f90
PROGRAM test
USE, INTRINSIC :: iso_c_binding
REAL*8 :: x(2)
LOGICAL :: l1,l2
LOGICAL(KIND=C_BOOL) :: cl1,cl2
! external functions
INTERFACE
SUBROUTINE cfunc(a,l1,l2) &
BIND(c, name='cfunc_')
REAL*8 :: a(:)
LOGICAL(KIND=C_BOOL), value :: l1,l2
END SUBROUTINE cfunc
END INTERFACE
x(1)=3.0
x(2)=4.0
l1=.TRUE.
l2=.FALSE.
cl1=l1
cl2=l2
call cfunc(x,cl1,cl2)
END PROGRAM test
cfunc.cpp :
#include <iostream> // std::cout
#include "cfunc.h"
void cfunc_(double* a, bool l1, bool l2)
bool ltest;
ltest=255;
std::cout<< "out: " << a[0] << " " << a[1] << " " << l1 << " " << ! l1 << " " << ltest << " " << ! ltest << " "<< std::endl;
if (! l1) std::cout<< "l1: Error (not True) is (True) !" << std::endl;
if (! ltest) std::cout<< "ltest: Error (not True) is (True) !" << std::endl;
cfunc.h :
extern "C" {
void cfunc_(double* a, bool l1, bool l2);
If I compile and run this I get:
+ g++ -c cfunc.cpp
+ pgf90 -lstdc++ cfunc.o -o test Main.f90
Main.f90:
test/C_Fortran> ./test
out: 3 4 255 254 1 0
I though that using iso_c_binding would help, but apparenlty it’s not. Do you have any idea/suggestions on how I could preceed ? (Note that if I compile with gfortran I don’t have this issue)
Thanks,
Xavier
PS : I have been using PGI 13.2
