Issue with connection to 2 dgx sparks. vllm
I’m trying to connect two dgx sparks using them to run larger models but currently running into issues.
There have been numerous posts about it. This one, for example - you can use my repo or Mark’s - his is a little bit more plug-n-play, I believe, but obscures some parameters. Mine is for more flexibility, but may not be as beginner-friendly. Also, my repo builds from the main branch, Mark’s solution uses official VLLM docker from NVidia (which lags behind in model support and performance).
